Alternator relocation bracket
the center hole on the bracket is mounted to what i would call the upper most hole farthest to the pass side on the cylinder head using a small spacer, and the slide type tensioner is mounted from the alt to the water pump where the stock tensioner mounted. had to take a little material off the alt here to get the alignment right
interesting, ive never looked at your belt system on your cars, didnt realize that your tensioner was in the same spot.
ill have to see if its worth it to me to my mine. my manifolds will likely have to point up
