where to find a good tt ls1 set up
Originally Posted by cablebandit
TTSS has a CAS kit up for sale. It is new....needs a few things to finish it but it is priced right!!!!
8 second mod
I have the CAS kit, the only issue i have had was with the headers cracking, But to pull them and weld them is accually easy. I do it in about 3-4 hours. it isnt bad at all. But i believe almost any kit with stainless headers has this issue. Heat wrap or coating them might help.
The cas kit is a nice quality kit tho.
Good luck
Good luck
Good luck
Good luck
Actually coating or heat rap will hold in more heat, which will cause more thermal expansion. Since the way CAS secured the headers does not allow enough expansion more heat would make them crack even more.
Gary
Good luck
Good luck
do you have any installed pics of this setup, i would like to see what the cas setup looks like, vs the incon that i have seen
Ryan.
8 second mod
Slow, it is quality, the headrs cracking seem to be the norm with any stainless header. I know some have had the same issue with the QMP as well as other custom kits so it isnt that big of a deal to me to pull them once a season and touch them up. I wouldnt recomend this kit to a no brainer with no mech skills, but for someone with ambition and that need for constaint speed it is a good kit, and everything ealse on the kit is A+
Jam, all the welds. it has small cracks on the flange and others on the flange for the turbo. I noticed mine with heat wrap done right seemed to have less this time then they did without heat wrap. JMO
I understand that any stainless steel fabricated header has the tendancy to crack, one of the reasons that if i ever decide to go turbo, i would like a cast manifold. Too bad they are not produced anymore.
I have access to a tig welder,and have a guy who knows what he is doing, so fixing them is not an issue, but it is just hard to buy a kit, that i know will have problems, that there does not seem to be a solution for. Repairs are alright, but i am the kind of person who would rather do it once, and do it right. (if possible)
Ryan
Ryan
Just missing:
2) Waste gates
Tubing/hosing assembly from top of intercooler to throttle body
Mounting brackets for intercooler
All hose couplers for aluminum tubing
(2) Air filters
Its TTSSZ by the by.
2) Waste gates
(2) Air filters
Originally Posted by joshs_ws6
Thanks or all of he help guys.I will be in touch with you ttss. you say all it needs it the manifolds?
Good luck
Good luck
