MIke (blackls1ta) Steel ATI bracket,
Old 02-01-2004 | 12:06 PM
scottywheels's Avatar
Default MIke (blackls1ta) Steel ATI bracket,
where did you guys get yours...need a #, I had gotten one but it fell through.
Old 02-01-2004 | 12:18 PM
frcefed98's Avatar
Here ya go, I need to order one soon too.
Automotion Performance / Jason Esher
303-670-5011
$180.00
J
Old 02-01-2004 | 12:54 PM
thanks J
Old 02-01-2004 | 02:24 PM
nbm00ws6's Avatar
Ordered mine last week.
Old 02-01-2004 | 04:14 PM
jrios's Avatar
I just received mine
Old 02-01-2004 | 04:49 PM
NA$TY-TA's Avatar
Thanks Scott for asking.... I need to order mine before everything goes back on..
Kyle
Old 02-02-2004 | 02:42 AM
BIGBOS's Avatar
I'm still deciding wether or not I want to order one of these, I got a bracket support made for the stock junk one, so I might as well stick with it...........might be a future upgrade to consider though since a few have had luck so far.........
Old 02-02-2004 | 04:19 AM
Black LS1 T/A's Avatar
Moderator
I figured I'd pop in this post with this thread.. it's GOTTA get lost in that popular long-azz thread BIGBOS started.
Jason Escher's (Automotion Performance) steel bracket is the bomb.
(303-670-5011, $180.00. Jason once worked for ATI, so he knew exactly what to do to get a precise fit.)
I climbed under my car to look at the belt and check things after my trip to West Virgina (780 mile round trip, plus mileage that week while working there), and after repeated WOT's, some high speed runs, etc, (even with the smaller 3.20 SC pulley and MMS crank pulley) I see no appreciable wear on the belt. And it's not as tight as I have had to keep it before, either. But, I'm still getting 13 to 14 PSI peak. With my old bracket (the one on the right), I would have broken several belts by now.
The original bracket was fine up to 10 PSI on my stock engine. But, I began to have these problems at even that boost level with the 422. There is just so much more torque down low, and even on the big end, intermittent contact between the idler and bracket could be potentially devastating. The soft depressions that occur from tightening and moving the idler bolt exacerabates the problem, because the idler is pulled in even closer AND they are no longer precisely perpendicular to each other.
I don't see how I could live without it at the higher boost levels. If anyone is seeing unexplainable belt slip and dips, I STRONGLY recommend you check the surface of the bracket area where the idler pulley might meet the bracket and gouge it... but worse, yet, suspend rotation and chew or snap your belt!
Old 02-02-2004 | 10:08 PM
automotion's Avatar
Default Just browsing.....
I haven't spoken much in this forum but I noticed this thread. I'm on my way to the machine shop right now to pick up 4 more of these brackets. 1 is spoken.. Speak up now if there are more than three takers. I'm probably a month out from the next run. I'm glad to see they are working well.
Jasone Esher
AutoMotion Performance, Inc.
303-670-5011
