383 + 2 x gt4788 =....
Old 11-14-2010, 07:26 PM
427_LSX's Avatar
Default 383 + 2 x gt4788 =....
Gday guys,
I am almost finished with my 427 and 106mm build and have some spare parts that never got used or i changed the direction of the previous build.
Im looking to just have some fun and build something that i can just mess around in and have fun.
I have a fully built 383 LS1 that has been built to handle around 1000hp as it was my previous motor and had only done less than 5000 miles.
2 garrett gt4788's with .96 ar and a huge selection of fuel components, and intercooler cores laying around so i wouldnt have a huge outlay of money to start another play car.
Do you think the littlle 383 could spin the 47's up?
Im happy to use a bit of NOS and understand that i could make similar power with a single 47 but i have 2 spare and might aswell use whats there instead of leaving it in the garage to be forgotten about.
Cheers.
Old 11-14-2010, 07:41 PM
MR2liter's Avatar
Do it and let us know what happens!
Old 11-14-2010, 10:38 PM
ries's Avatar
x2 GT4788's
just do a single and give me the other one
Old 11-15-2010, 02:30 AM
AES Racing's Avatar
383 would have enough on its hands with 1 GT4718 turbocharger, and should be full capable of 800rwhp through a TH400.
Still would be better off with our 390ci iron block setup vs. 383 with 5.7 alloy block waiting to crack.
Old 11-15-2010, 04:36 AM
Nitroused383's Avatar
Just one GT 47-88 is more than capable to scatter your 1000 hp short block. You're looking at 130-140 lbs/min depending on how much boost. Late Model Racecraft runs two GT 47-88's on their drag radial car, it makes 2500-2800 horsepower. By the time you actually spool two of these turbos your powerband is going to be very short unless you are spinning it 8000-9000 rpm.
Old 11-17-2010, 05:28 AM
427_LSX's Avatar
I completely understand that it is going to be a pig to drive and wont be on boost until over 4-5000rpm. If it was to make boost around 5000-5500 rpm i would do it just for a laugh and to get some funny looks.
Im not out to shatter horsepower records im just looking at a cheap fun project as i have 80% of the things needed already.
if it was to make 800hp through a th400 i would be happy with that because the car i plan on throwing it in only weighs 2400lbs stock.
Old 11-17-2010, 11:12 AM
93formto98T/A's Avatar
It would only make sense to run 1 GT4788. It should be fun and reach your power goals in that arrangement.
Old 11-17-2010, 11:15 AM
Restricted User
98Z28CobraKiller's Avatar
Yeah, sell the second one or throw it on a work truck or the wife's car if your bored. LOL
Old 11-18-2010, 07:24 PM
MR2liter's Avatar
Here is a fellow Aussie that got it done with a 383!
https://ls1tech.com/forums/multimedi...-just-wow.html
Old 11-18-2010, 07:56 PM
Restricted User
Looks good on a dyno sheet.
Quick Reply: 383 + 2 x gt4788 =....
