View Poll Results: which cam you think is best
244/247 .664/.664 115
0
0%
248/244 .660/.660 115
5
100.00%
none of above
0
0%
Voters: 5. You may not vote on this poll
TURBO CAM (match or rev. duration)
Old 11-20-2010, 10:07 AM
lordrazo's Avatar
Default TURBO CAM (match or rev. duration)
here are the two cams im deciding on with lloyd elliott
or
I have a lt1 396 stroker splayed lt1
afr 210cc comp port #1101 64cc
victor efi port matched to heads 1206 gasket
elbow with 90mm tb
je custom -31cc pistons
lunati 5.85 forged rods and calies forged crank
pro turbo kit gen 2 just large dump pipe no exhaust
160 lb. Injectors running e85 fuel and a FAST ecu
S-88 built 88mm compressor wheel, 3" slip discharge race cover, 1.32 a/r exhaust housing, divided T6 flange
fti th400
fti custom converter
12bolt 3.42 gears
28" tire
race weight with driver 3500 lbs
I want max effort 20-25 lbs boost high hp trailered drag car little street driving running
big solid roller cam with a 1.6rr
im probably going to redline @7000 rpm
im looking to make around 850 but would like to hit that 1000hp on the dyno
Old 11-20-2010, 12:42 PM
Hank Peabody's Avatar
Since its mostly a drag car how abut a GT91 turbo instead of the PT88? I dont know about the cams, probably either would be super strong, they are very close!
Old 11-20-2010, 01:16 PM
lt1773's Avatar
go ahead since the lloyd elliott specs for you then %100 no need to get worry about anything ,he is the best man who knows about the lt1/4 engines .
Thanks
SALEH
Old 11-20-2010, 04:21 PM
lordrazo's Avatar
sorry wrong turbo heres the one i purchased
S-88 88mm compressor wheel, 3" slip discharge race cover, 1.32 a/r exhaust housing, divided T6 flange
Old 11-20-2010, 04:29 PM
Oooh yeah tasty turbo, good choice!
Old 11-20-2010, 04:43 PM
lordrazo's Avatar
thanks hank ya i cant wait to spool it up
Old 11-20-2010, 09:38 PM
lordrazo's Avatar
any one can help me understand rev. split cams i was under the impression that it was designed for low flowing heads and exhaust
Old 11-21-2010, 08:18 PM
lordrazo's Avatar
Old 11-22-2010, 10:11 AM
9sec93's Avatar
why solid roller if you are only going to spin it to 7k?
Old 11-22-2010, 04:29 PM
lordrazo's Avatar
well originally i was going to spin up to 7600 and have the ability in my valvetrain to do so but lloyd elliott thinks 7000 will be my good redline and turbos love sold which im sure you already know
Quick Reply: TURBO CAM (match or rev. duration)
