Would this be a good turbo?
Old 11-26-2010, 05:08 PM
confuzzled's Avatar
Default Would this be a good turbo?
This would be going in front of a 383 LT1 with 9.5:1
http://www.wannaspeed.com/index.php?...roducts_id=186
Old 11-26-2010, 06:23 PM
rotary1307cc's Avatar
not with the P-trim turbine
you would atleast want a Q
what trans?
Old 11-26-2010, 06:24 PM
speedsk899's Avatar
https://www.turbodaves.com/Home_Page.html
call this guy he will help you out with a good set up!
Old 11-26-2010, 08:52 PM
confuzzled's Avatar
I'm putting a 6 speed in the car.
Old 11-26-2010, 09:13 PM
confuzzled's Avatar
So this one then?
http://www.wannaspeed.com/index.php?...roducts_id=187
Old 11-26-2010, 09:37 PM
CarsandWomen's Avatar
you dont want anything that says T3 it needs to be T4 or T6
Old 11-26-2010, 10:10 PM
openboost's Avatar
my friend owns a turbo shop, I once used a master power t-70 with 96.ar rear housing on a stock ls1 arp rod and head bolts ,72cc heads from 6.0L to drop compression to 9.1 .the car put 522 to the wheels then my friend put a q-wheel an the car made 50 extra hp. I think that i can get that or other turbo for a better price, people talk a lot of crap but those turbo are not to bad.
Old 11-26-2010, 11:19 PM
Originally Posted by confuzzled
yes better
just a little heads up to you the Q is similar to the popular F1-68 used in the turbonetics TC78/76's
P similar to the F1-65
you definitely would want atleast the 1.0 A/R they have listed or bigger
should work good on a M6 that isn't being pushed too hard
Old 11-27-2010, 03:08 PM
confuzzled's Avatar
I'm a little confused on the A/R part of it. I'm looking for a turbo that will start kicking in around 2,800 and pull to 6,500-7,000rpm.. They offer that turbo in a 1.0A/R T4 divided, so would that be the one i should grab?
sorry kinda new to this turbo stuff, just wanting to make 650whp.
Old 11-27-2010, 03:38 PM
just looking at what youve said in your posts, research the difference between a divided and undivided housing. In doing this research you will learn lots, check the Turbonetics website for a lot of good info. I say this because i was in your shoes not so many days ago, the more you read, the better you will feel about your choice.
Quick Reply: Would this be a good turbo?
