Alky meth kit, but need windshield washer
Not sure this is the right forum for this but here goes. I'm running with a turbocharger and the Alky control kit using the stock windshield washer fluid container to hold the methanol. Just moved to NC a few months ago and I'm thinking I'll probably need a working windshield washer system to pass inspection.
For those of you who have the same Alky set up and need to pass vehicle inspections, what are you using for a windshield washer system? Is there a universal kit that anyone can recommend?
Not really sure if they check this but I can't imagine a vehicle inspection without a wiper/washer check.
If you use pure methanol, you will need a separate tank anyway. Pure meth will eat your pump seals for the WW, and if you spray your windshield pure meth will streak your paint. If you use a 50/50 mix, as someone else suggested, you're golden. It all depends on the percentage of meth your combo likes.
Thanks for the replies everyone, that's all good info. AFASTYZFR1, that is bada**. That's exactly what I'm gonna do.
