skool me on f-body turbo setups
is it worth the money to get a kit? does anyone make a decent single front mount kit? was looking at kentucky turbo performance's kits i'm looking for something to keep all my accesories so i would have to run 6.0 vette manifolds i believe.
http://kentuckyturboandperformance.com/turbo.html
or would one just be better off making their own kit? i don't weld so i would have a friend who is a good welder do so when the time comes but just looking into options as i don't see many out there.
current setup is a 6.0 lq4 with fresh 317's on them and a torquer v.3 cam and spray. i'm looking to get away from spray i want to keep the 6.0 put some pistions in it bored over and prolly do a nice set of rods while i'm in there.
still have a stock ls6 intak on it. will that hold me back much? i want to make 600whp roughly for now on a conservitive tune.
what do you guys think any suggestions on what my options are?
thanks,
jeremy
thanks,
jeremy
the kit would make life alittle easier, and your friend is going to have his hands full, but its nothing anyone with alittle know how, and some time cant do themselfs.
600rwhp is conservative, could be easy on low boost, and with a small turbo.
There is alot of little stuff that is involved; fuel system, cooling, oil for the turbo.. the list goes on..
READ as much as you can, and take your time.. it will be worth it in the end..
goodluck
goodluck
If money isn't a concern then just get the kit, but If you piece your kit together it is relatively cheaper. The LS6 IM should be fine for what your goals are "600hp" it has been done over and over again.
Use the Search function, there are many turbo builds with lots of information in them.
11 Second Truck Club
if youre only going for 600 from a 6.0, the stock bottom end will be fine, unless its got a bunch of miles, save that money and put towards the turbo and supporting stuff.
building your own kit will save a ton of money, and really isnt that hard.
i did my own rear mount setup so i could keep a/c, and been VERY happy with it.
Has anyone heard of or used these kits?
Money is a factor so I'd like to not **** it away lol. Those that have done your own kits what do you end up spending to build just the kit and parts?
Turbo
I never herd of them but i was going to go turbo at one point and i did look into the STS kit to me it looks very nice and complet and the way the kit is put to gether you can upgrad parts with out having to buy the hole thing all over i called them and they are nice over there JUST SAYING
Front mount ftw!!!
Ky turbo has some pretty nice looking stuff. If you want to keep cost down, just build it yourself, and be done with it. It might take a couple trys, and a few nights of sratching your head, but atleast when your done, you can say YOU built it. Then use that extra cash to buy the rest of what you need to get it all done..
The last I heard you couldn't change the turbos for the twin kit. I'll have too see if they have any singles.
What I'd really like is to see on3performance make I've for these cars. They do great work for the mustangs at a unbeatable price!
The little bit of number crunching ive done, you can do a single front mount truck manifold kit for around 1700 with a MPT76, Now i didnt take into consideration of the gauges,lines, and fuel injectors. But all should still be south of 2500 if you hit up the forsale section. Im a complete noob at this, but thats what ive come up with
a good wastegate and a nice blow off valve will be around $600-$800, the MPT76 is $750ish (i think), front mount intercooler will be $150-$200.a good supporting fuel system at the very least is going to be $700ish, im talking dual pumps, 60lb injectors, boost referenced FPR. if you can manage to fab the kit and keep the stock radiator and only buy pusher fans then those will $100-$200
thats over $2000 not including piping, flanges, and other miscellaneous items mentioned. seriously, in the end you will spend VERY close to what a basic kytp costs unless you find killer deals.
^I picked up a KYTP kit with a TC78. Can't wait to get it in my grubby hands. There is so much more to getting a turbo than just getting the kit. As others said, walbro single or duel fuel pumps, injectors, maybe a cam and springs, and gauges to name a few. I'm going a little further out because I picked up a FLT level 6 trans and s60 rear end which we just finished installing. I guess what I'm saying is do your homework which sounds like what you are doing and plan on not skimping out on supporting mods.
Only problem I see running into would be weather changes...but with my whopping 50-100mi a year it gets driven, I dont see it being a huge issue at first
My suggestion is give Josh a call. He will take the time to discuss whatever you want to do as far as a kit, accessory retention, hp potential and street or strip duty. He can do anything you want (within reason). The problem is that Josh is only taking on orders as he can do them in a timely manner. Spots fill up FAST when he gives the nod for more orders. He has done everything from cookie cutter kits to full one off race kits. He's had a lot of high end builds in his shop. The big thing is he isn't some guy that is here today and gone tomorrow type of thing. You can call him today, you can call him tomorrow and if you call him on tuesday of next week during the day he'll answer then too. Great guy to deal with and does great work. I am pleased with the craftmanship on my kit. I have yet to finish the car but I'm getting closer. I think he might be taking orders here soon so if your interested you had better get a call in! Anyways hope that helps. Chris
I will tell you some friendly advice though, turbo cars are not for the faint of heart and definitely not if you are planning to do a big hp kit. The engine/turbo kit is just the beginning. Most (myself included)think that those two things are the biggest cost out of the whole build. Wrong! I have spent a ridiculous amount of money on that car and I'm still finding more stuff to put on it that I need! Keep that in mind.
