Final stages- PTK FRC PICS
Down to the final hour. I've got a few things left but I figured i'd start a thread to show progress of where i'm at. Hopeing to be done within a week or soo... I have a few more things to do AERO wise as well soo,..this isn't final, nor is the car clean. Lemme know what you think.
OLD PIC-
New pic
and some solid roller eye candy we have laying around for another ride...
OLD PIC-
New pic
[QUOTE=Tally TransAm;14429872]digging the exterior mods. badass man[/QUOTE
Thanks bro, appreciate that.
Thanks man, precision 67mm T4 turbos, goals are 1xxx rwhp, runway/highway ready,...looking for 2X0mph in the mile...and a few south fla cars and bikes.
specs-
364ci LS2 diamond pistons/eagle rods
TEA 235s w/bronze guides/seats 700 lift springs
pretty narley turbo cam from V speed i bought second hand
magnafuel xl750 pump with -10 feed, -8 return Ford 160s with acceleronics driver box
E85
currently have an Ls2 intake but, i want a fast 92 ...i have a wilson billet manifold but, I'm hearing its not good for boost, so, probably gonna run a fast 90-92 but, i dunno
other then a few other things, that's it.
oh.... i run a 6 sleed with 2.73 gears...last time with a stock heads and cam LS6 i ran 11 psi(787rwhpout of fuel @5800rpm)... planning on doubling that if needed.
thanks alot man.
OLD** build thread, if you wanna see the blower to turbo swap-(old motor)
https://ls1tech.com/forums/corvette-...self-pics.html
current build thread- https://ls1tech.com/forums/corvette-...aser-pics.html
Pic from DREWSHOOTS(drivermodF-W)...more to come-
thanks guys, i appreciate the words. I gotta order a wideband for the car hopefully this week, finish up a few other things, hopeing to have it started.
what's left?
wire in versafueler
some how bolt my fast rails to the LS2 manifold
lengthen cam sensor
lengthen map sensor
route vac lines
power fuel pump
mount and relocate power steering tank
add coolant
make airfilters
test fuel system, add e85
and probably a few other bells and whistles.
what's left?
wire in versafueler
lengthen cam sensor
lengthen map sensor
route vac lines
power fuel pump
add coolant
make airfilters
