Fairmont 2.0 (forged lq4, s480, 800whp, under new management)
Old 03-21-2012, 06:46 AM
  #101
1fast bird's Avatar
Originally Posted by 98Camarod
Nice build man! Where are y'all getting these motors so cheap? Every where around here wants over 800 bucks for just a 4.8 and even more for the 5.3 and 6.0
I'm guessing it's cheaper if you pull them from the vehicle instead of the salvage yard doing it. I'd love to have a few $80 motors sitting around. Could have 10 of these if I didn't buy rods for my motor
Old 03-23-2012, 08:29 PM
  #102
Moderator
denmah's Avatar
installed an alarm today
and my tru boost
gate is 13.8psi
and i set A = 25% and it hit 16
i set B = 35% and it hit 18lbs
incontrollable, gunna put the slicks on and put it on my friends mustang dyno with big *** rollers. and shoot for 20lbs.
i have spring crack set on 10lbs and it builds boost fast as **** now haha
Old 03-24-2012, 02:13 AM
  #103
b16acrx1988's Avatar
This car is bad ***, I love these budget builds.
Old 03-24-2012, 11:14 AM
  #104
Zerex's Avatar
Great looking pit!
Old 03-25-2012, 10:54 AM
  #105
shawn_c992001's Avatar
Very nice!
Old 03-25-2012, 02:02 PM
  #106
camarodude87's Avatar
thanks for this build.. inspiration !
Old 03-26-2012, 09:28 AM
  #107
Moderator
denmah's Avatar
Originally Posted by Zerex
Great looking pit!
thanks! she is a good girl!
Old 03-26-2012, 08:07 PM
  #108
stangtrader's Avatar
you will be totally fine, i start on 15lbs with these motors, they are BEASTS.
leave it all stock, leave it together, dont even pull a valve cover.
Quick question since it came to mind. Are you still running stock valve springs?
If so have you experienced any valve float cause of it? I've always heard after 7ish psi they will float.
Thanks
Old 03-26-2012, 09:29 PM
  #109
831jd's Avatar
and my tru boost
gate is 13.8psi
Have you tried the on3 turbos any Good results if so?
Old 03-29-2012, 10:32 AM
  #110
Haddixj's Avatar
Is there any reason to not go with MS3 and do the fuel and ign with it? I am looking into changing out the 454 in my chevelle for a jy 5.3 that I have and adding a cheap turbo setup, my car is a 4 speed car though so I was going to go with a smaller turbo so I can have quick boost recovery.
Old 03-29-2012, 05:07 PM
  #111
quarterstang86's Avatar
I stumbled into this build and your website elsewhere. Thanks for all the documentation and for putting this out there. Sick car dude.
Old 04-01-2012, 07:03 PM
  #112
Moderator
denmah's Avatar
goodnight sweet prince.
ive had a strange vibration at higher speed, 55-65+ lately, and ive been trying to sort it out, redid my trans mount, bought poly trans mount, re did all the bearings in the rear re-shimmed, not that, put on a set of mustang alloys with good tires and drove it last night, heard a little noise but couldnt pin point it.
broke an axel driving about 65mph (no speedo so i have no idea)
since its drum rear it spit the axle right out the side of the car and dropped me on the diff and axle tube, instant 180 into the other lane of traffic with no brakes, since it tore the drum off... luckly strait into a huge grass hillside, where it proceeded to bend the rear bumper under the back of the car, twist the frame, blow the trunk, etc. windows all stayed intact and im fine, actually the car stayed idling and i drove it out of the feild and down the street into a large parking lot and had corey come pick it up with the flatbed.
ill get some pics of it then, oh well, everything else seems good, gunna tear the stuff out and build another.
i can see the axle stub still in the rear with a flashlight.
Old 04-01-2012, 07:04 PM
  #113
Moderator
denmah's Avatar
i picked up this gem saturday morning to replace my dear fairmont
2.0
Old 04-01-2012, 07:09 PM
  #114
96gt4.6's Avatar
WHERE do you find those things that NICE!!!
Glad you are ok bud. The 2nd thing I did with my pile was c clip eliminators, I too have drum on my 8.8", and it isn't worth dying over indeed.
Having a fully welded carrier is kinda rough on the axles though on the street, might have had a hand in it?
Can't wait to see 2.0 up and running!
Old 04-01-2012, 07:12 PM
  #115
adamantium's Avatar
Your a miscer?
BTW how much heavier is the 4 door over the 2 door? I like the 2 door alot more for some reason :/
Old 04-01-2012, 09:11 PM
  #116
BottleFedZ346's Avatar
Glad to see your ok man!
Goodluck getting everything swapped into this new chassis!
Old 04-02-2012, 12:17 AM
  #117
a4ls2goat's Avatar
Glad to hear your ok.
so your pretty much just swapping everything to the 4door?
Old 04-02-2012, 12:18 AM
  #118
Moderator
denmah's Avatar
yep aside from some wiring and cutting, should go nicely.
gotta get a new 8.8
Old 04-02-2012, 12:38 AM
  #119
a4ls2goat's Avatar
Do make vids!!!
Old 04-02-2012, 09:00 AM
  #120
6point7s14's Avatar
Hate to hear that, good luck with 2.o tho.... Keep us updated
Quick Reply: Fairmont 2.0 (forged lq4, s480, 800whp, under new management)
