How much boost will a 7" crank pulley and a 3.4" pulley make on a D1 sc procharger
JUst like the title says . How much boost will my d1sc procharger make with a 7" crank pulley and a 3.4 head unit pulley give or take. I know there are a lot of factors. But just a round number for the intjector estimate. The set up is a ls2, 232/240 .595/.608 115 lsa cam and ported 317 heads thanks for any help
54343 blower rpm with 7" crank and 3.4 pulley based on 6600 engine rpm boost = ?
What my car sees 47520 blower rpm 7.65" crank and 4.25 blower pulley based on 6600 engine rpm I see boost 11lbs 347ci ls1 h/c
Hope this helps
Hope this helps
He's been having a small problem for a little while now. We were all trying to help and iron it out. When I had my D1 combo I had a 7.25" SDCE crank pulley with a 3.70 blower and was seeing 11psi or so. You should see more then that on your combo...I'd guess around 15psi.
LS1Tech Sponsor
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
I know this is old but its exactly what ive been looking for I have the p1sc1 on my ls1 with the 3.4 pulley and im omly gettin about 3psi at 6000ft and procharger told me to upgrade my crank pulley what size should i go to and what psi would i be looking at its a stock bottom ls just a few bolt ons`
LS1Tech Sponsor
You're going to need top upgrade to the eight rib kit, shown in the above link. It has a 7.65 crank pulley. I would go with the eight rib 3.40 blower pulley. You are going to need the 918853 harmonic balancer and I would go with the crank pinning kit. You should see approx 6-7 psi with the change, it will make a huge difference in power. Bob
__________________
[QUOTE=Bob@BruteSpeed;17231288]http://shop.brutespeed.com/ATI-1GJ11...-1GJ115-08.htm
Alright cool so I wouldn't really see much of a difference if I upgraded the crank pulley with the 6 rib kit?
LS1Tech Sponsor
[QUOTE=zackyv55146;17231684] You would if you could find one. ProCharger doesn't make one, there have been aftermarket companies that have in the past. I bought one back in 2002 which make a big difference in boost with my D-1SC. It took it from 7 psi to 15 psi, and was made by SSM I believe. You may find one of these used, but no one makes them anymore. Bob
__________________
The following users liked this post:
Dre0396 (02-03-2021)
