Truck manifoldkit with stock k member?
Old 04-14-2012, 06:39 PM
wg871's Avatar
Default Truck manifoldkit with stock k member?
Has anyone out there fabbed a truck manifold kit while using the stock k member? Is this possible or is a tubular k member absolutely necessary? Thanks
Old 04-14-2012, 07:55 PM
ep142's Avatar
it can be done, just have make some clearance on the passenger side.
https://ls1tech.com/forums/forced-in...hlight=modular
Old 04-14-2012, 08:18 PM
a-low's Avatar
Huron kit uses stock k member
https://ls1tech.com/forums/forced-in...ifold-kit.html
Old 04-14-2012, 08:45 PM
Ping King's Avatar
What are your goals for power? Your downpipe size is limited with a stock k member. I was able to stuff a 4 inch DP over the motor mount, but i couldn't use a pass truck manifold.
Old 04-14-2012, 09:03 PM
Captain Double Post
BOBS99SS's Avatar
i plan to do mine with a stock k member, my plan is to cut a hole in my car for a dp lol
Old 04-14-2012, 09:17 PM
95maroz28's Avatar
i did but have solid mounts, the studs pretty close on passenger side just had to grind enough to get a wrench on it
Old 04-14-2012, 09:55 PM
Tally TransAm's Avatar
still running a stock k member with no plans on changing
Old 04-14-2012, 10:57 PM
fastsspr's Avatar
What you used to replease the truck manifold ?
Old 04-15-2012, 12:20 AM
boss79z's Avatar
Stock k member here. No grinding on k-member her. We popped the stud off the manifold and replaced it with a shorter bolt.
Old 04-15-2012, 12:36 AM
Sweet_SS's Avatar
Stock K member here as well
Old 04-15-2012, 02:07 AM
BottleFedZ346's Avatar
Stock k-member here as well, no grinding or notching done....
I do however have v-bands on the manifolds rather then the stock flanges....
Old 04-15-2012, 09:51 AM
Adam86's Avatar
Stocker here. Had to do a little notching though.
Old 04-15-2012, 10:24 AM
JaYZeig's Avatar
stock k member here..with 3.5 in downpipe...of course with spohn solids, they free up so much room!
Old 04-15-2012, 07:16 PM
Ryans99ls1's Avatar
stock notched kmember here. welding vbands to the manifolds is the best option if you dont want to notch anything
Ping King's Avatar
I built a forward swept turbo manifold.
I also have a build using a stock pass and a flipped truck on the drivers side.
Its tight, but i fit a 3" DP as well as retained AC.
Quick Reply: Truck manifoldkit with stock k member?
