One Guy's Garage 71 Nova TT 5.3, The Quest for 7's.
Old 09-20-2014, 08:51 AM
  #361
LanceL's Avatar
Nate, did you just take the whole radiator and fan assembly right out of the car you hot it from? I can't remember what car? Or is the radiator and fans separate and you combined them? Did you just spray paint them? Great pictures you gave all of us!! Great ideas! Thank you for your help.
Old 09-22-2014, 05:34 AM
  #362
LS1NOVA's Avatar
Originally Posted by Ratical
So it just plugs in where the LCD would on the Holley box or where the laptop would connect? Can you still make adjustments like the Holley display also? That was a great idea.
The tablet uses a USB cord. The Holley screen uses CAN wiring. The tablet can do everything. Display, tune, whatever. The downside is you need to start it up every key cycle. The Holley just powers up with the key automatically.
Originally Posted by Chicago TDP
Hows that 12 bolt holding up?
What axles, carrier and gears?
C-clipped?
Just curious to how far I am willing to push mine
Its been very reliable. It has a stock carrier (untouched in 20 years), Superior c clip axles, and a Richmond gear set. Has four brake calipers as axle retention devices...
The radiator is a universal 31x16 Northern dual pass. The fans are Ford Contour iirc. I welded brackets to the radiator for the fans. It is spray painted. VHT Low gloss black is the best aerosol paint ever made.
Old 09-30-2014, 07:23 PM
  #363
Ratical's Avatar
Thank you. I don't mind turning the tablet on when I start the car.
Old 09-30-2014, 10:36 PM
  #364
BanditDave's Avatar
Lol...that's funny, I was just telling a car buddy at work the same thing. Use it EVERYWHERE. Awesome build Nate.
Old 10-07-2014, 06:49 PM
  #365
LS1NOVA's Avatar
C-clipped?
Ok who is the *** that had to bring up the rear axle....
Went to the track Saturday. Launched on a 1.32 60ft, felt amazing, then bang bang bang.
Thought it was the input shaft but turns out the stock limited slip carrier and spider gears decided their time was up.
Guess my quest for 8's is done for the year. Going to be a long winter.
https://www.youtube.com/watch?v=FYGl...ature=youtu.be
Old 10-07-2014, 06:55 PM
  #366
cam
cam's Avatar
Spool time
Old 10-08-2014, 07:59 AM
  #367
transam69230's Avatar
Fix it and let's both make a trip to Byron! They run late into November!!
Old 10-08-2014, 11:19 AM
  #368
Slow94Formula's Avatar
Too bad it couldn't stay together for just one more pass... at least you weren't the only one that broke something that day.
Old 10-08-2014, 11:21 AM
  #369
Only ERO's's Avatar
The proper word is destroyed.
Old 10-08-2014, 11:27 AM
  #370
True... The track did cause quite a bit of destruction.
Old 10-08-2014, 12:09 PM
  #371
RonSSNova's Avatar
A spool on the street prob won't fit what Nate does with the car.
There are good strong options for a posi type diff.
Tom's Differentials is a good source.
Sadly, the NHRA doesn't recognize the disc brakes as axle retention devices. Which I think is dumb.
Amazing the stock posi lasted that long!
Ron
Old 10-08-2014, 01:54 PM
  #372
Chicago TDP's Avatar
Sorry...just had to ask!
You put that "stock" 12 bolt through hell for sure, I am surprised it went this long with all that abuse.
Old 10-08-2014, 07:02 PM
  #373
94 slow's Avatar
Nate,
Is that the factory/stock size radiator that you are using?
Old 10-08-2014, 07:08 PM
  #374
rotary1307cc's Avatar
That would of been your 8!
Old 11-03-2014, 01:13 PM
  #375
LS1NOVA's Avatar
Took a trip down to Cordova on Saturday. Got into the 8's with an 8.94. Decided to go to Byron yesterday and ran a 8.82 at 153. Great way to end the season.
Old 11-03-2014, 01:23 PM
  #376
BanditDave's Avatar
Hell yea, Nate!!!
Old 11-03-2014, 01:57 PM
  #377
98Camarod's Avatar
Congrats! Any video?
Old 11-03-2014, 03:45 PM
  #378
Moderator
denmah's Avatar
i believe i have commented on this thread a few times before but what a badass build! seriously awesome work, thank for sharing all the crazy fab work, it gives people ideas for their builds!
Old 11-03-2014, 04:14 PM
  #379
98Camarod's Avatar
What did you paint the firewall with and how did you transition the intake tube through the firewall?
Old 11-03-2014, 08:17 PM
  #380
1972nova's Avatar
any pictures on that intercooler plumbing... cool setup
and what kind of IAT are you getting with that type 22?
Quick Reply: One Guy's Garage 71 Nova TT 5.3, The Quest for 7's.
