how much boost with no tune ?
Old 07-04-2012, 12:30 AM
devic's Avatar
Default how much boost with no tune ?
how much boost can a ls1 take with out a tune safely ? and how much power would it gain ?
Old 07-04-2012, 12:42 AM
itsslow98's Avatar
None safely
Old 07-04-2012, 12:58 AM
TX RED's Avatar
Old 07-04-2012, 01:04 AM
devic's Avatar
i was thinking 6-8 pounds on diy remote setup
Old 07-04-2012, 01:11 AM
Tally TransAm's Avatar
i would highly advise against that
Old 07-04-2012, 01:16 AM
9 Second Truck Club
stock48's Avatar
Yea definitely not a good idea. Maybe if you have a variable meth controller w/100% and 2 large nozzles and really watch the afr gauge.
Old 07-04-2012, 01:17 AM
devic's Avatar
dang is it really that sensitive to the boost ?
Old 07-04-2012, 01:54 AM
if you put 6-8 #'s on any NA vehicle with factory tuning its not gonna end well
Old 07-04-2012, 02:00 AM
devic's Avatar
can u get tune's so that u dont have to run the boost and it with still operate normally
Old 07-04-2012, 02:10 AM
skinnies's Avatar
I'd just advise you don't try to do boost at all.
Old 07-04-2012, 02:13 AM
devic's Avatar
doesnt answer my question,
i just need to know if u can tune the pcm, so that it will operate under boost , and no boost
simple question
Old 07-04-2012, 02:17 AM
simple answer: yes
friendly recommendation: spend some time reading around and the vast majority of your questions will be answered
Old 07-04-2012, 02:28 AM
devic's Avatar
how should i phrase a search to inquire about mutli purpose tunes ?
Old 07-04-2012, 02:35 AM
a4ls2goat's Avatar
Stick with the mods on your Sig.
Your nowhere near ready for a boosted motor.
Old 07-04-2012, 02:45 AM
XpEdItIoUs's Avatar
Keep reading, we are not trying to be ******** here but you got a long ways to go before you consider boost.
Old 07-04-2012, 02:49 AM
XpEdItIoUs's Avatar
simple question
to answer this question, a pcm tuned for a boosted motor will run off boost and boost (over 100kpa at sea level). But you can't run a pcm tuned for just n/a and boost it because it will :bomb
Old 07-04-2012, 03:15 AM
NemeSS's Avatar
Actually,
You can run on the stock tune, with low boost, 5,6 o.r less psi.
But u will need an fmu, return fuel fpr at the rail,larger injectors and fuel pump upgrade at a minimum. Many sc/tc kits were sold with a fmu for fuel enrichment under boost. so is it possible, to run on the stock tune. With or without boost, since the fmu provides a huge amount of fuel pressure/volume at the injectors. But is not optimal for a real high hp motor.
There is no real substitute for a proper tune, and a return fuel system with a rrfpr for a serious forced induction build and a complete recalibration of the tune. No way around it.
Old 07-04-2012, 04:45 AM
devic's Avatar
im just asking to kinda find out where i want to go with my car, i plan on getting a cam, and i can fab up my own system just not sure as far as the tuning aspect of it goes
and im kinda wanting the turbo to just be on demand kinda not in use all the time
Old 07-04-2012, 04:47 AM
devic's Avatar
if i switch over to speed density will it make this easier, than running off the maf and the map sensor ?
Old 07-04-2012, 05:23 AM
devic's Avatar
and doesn't some 1 make a fuel regulator the ups the ratio of fuel vs boost, there for no longer needing a tune at low levels ?
Quick Reply: how much boost with no tune ?
