Camshaft Recommendations
Old 07-09-2012, 07:46 AM
69ChBuLQ4's Avatar
Default Camshaft Recommendations
Hey everybody, I have a stock lq4 6.0l 317 heads with a gm hotcam and im installing a turbonetics hurricane tc76 with 8-10psi of boost. I am wanting streetable low to mid horsepower for my build and have been looking at going with an ls6 cam. I also just saw this from hawks thirdgen and thought it might be a good fit:
http://www.ebay.com/itm/Custom-Grind...f7651e&vxp=mtr
any recommendations would be much appreciated!
Old 07-09-2012, 01:27 PM
intenseblue's Avatar
Check out Speed Incs TU1
Old 07-09-2012, 01:46 PM
69ChBuLQ4's Avatar
thanks for the suggestion, does it idle pretty smoothly with that lift and lsa?
the guy from lunati suggested this:
http://www.lunatipower.com/Product.aspx?id=2017&gid=281
Old 07-09-2012, 08:14 PM
Fbodyjunkie06's Avatar
224/228 .578/.585 114+2.
Old 07-09-2012, 08:27 PM
buick_lsx's Avatar
i have the TU2 on my 6.0, 317's, 75mm setup and love it...most say the tu1 is enough but everything works good on my setup
Old 07-09-2012, 10:10 PM
69ChBuLQ4's Avatar
that tu1 sounds pretty good on videos, a little choppy. not as bad as the hotcam, it was kind of a lot of bark and not much bite till higher rpms for me.
Old 07-09-2012, 10:46 PM
buick_lsx's Avatar
On my setup the tu2 picked up 40 rwhp over the ls6 cam with 5-6 degrees less timing
Old 07-09-2012, 11:11 PM
69ChBuLQ4's Avatar
nice, at wht rpms did it pick up the hp?
Old 07-09-2012, 11:18 PM
buick_lsx's Avatar
All across the board with faster spooling as well...peak power went from 5800 to 6400 too
Old 07-10-2012, 06:09 AM
pimpjames's Avatar
I purchased a FI Brute Speed Cam from Bob for my build (Similar to yours)
http://shop.brutespeed.com/Brute-Spe...d-Camshaft.htm
Old 07-10-2012, 09:50 AM
69ChBuLQ4's Avatar
ive been even thinking about lower duration and lift cause i don't really wnt to sacrifice any idle. whats the idle like on the tu2 and that brute?
Old 07-10-2012, 10:00 AM
Camaro9969's Avatar
If you want to hear the TU2 cam heres a video of mine. Havent gotten the turbo on yet but you get the idea.
http://youtu.be/eatPFiXkT5o
Old 07-10-2012, 10:18 AM
qqwqeqwrqwqtq's Avatar
In my opinion, run the smallest cam that will still allow you to get max HP out of the turbo.
We've run the TU1 with a single 7675 at over 900rwhp. TU2 we've used plenty of times at 1,150+rwhp with twins.
For the OP, an LS6 or TU0 cam is more suitable for that combination. More cam will only soften up the bottom end and mid-range.
Old 07-10-2012, 10:38 AM
69ChBuLQ4's Avatar
hah i actually had your video come up on youtube when i entered tu2 the other night.
ya that has some chop, it sounds vicious but im thinking more of a sleeper daily driver application for me maybe the tsp 220/220 .581" 114 lsa
Old 07-10-2012, 01:16 PM
69ChBuLQ4's Avatar
Ya the tu0 looks good too, it probably idles more smoothly than the tsp220, Im looking for around 550 rwhp
Old 07-10-2012, 02:59 PM
Camaro9969's Avatar
Haha ya it sure is choppy. Fbodyjunkie and speed in both told me the same cam for my set up (tu2). I want to drive it a lot on the street as well and I like the idle haha hopefully it makes some good HP but ill tell you a lq4 Turbo will never be a sleeper.
Old 07-11-2012, 12:16 AM
Your turbo size had a lot to do with that too.
You have a bigger compressor and a much bigger turbine side and that will make your turbo 10x more efficient than his on a 6.0 with the size of your hot side.
His turbo is much much smaller than yours and needs a lot less exhaust duration and you also wanted something that sounded vicious and ran great at the track
That's why I would use my spec in my first post. 224/228 .578/.585 114+2 or really a simple 224/224 .578"/.578" 114+4 would work just as well and be more mild on the exhaust side of things.
Old 07-11-2012, 01:12 AM
69ChBuLQ4's Avatar
ya the tc76 is pretty compact with a small 3" exhaust, im hoping for fast spool but i know i cant make gobs of power on it. that sounds good thanks for the suggestions
Old 07-11-2012, 01:33 AM
9 Second Truck Club
stock48's Avatar
What's with all the HUGE cams lol over the last couple years I've tested from 209, 212, 215, 221, 228@ .050 112 to 115 lsa on a 6.0L with 317 heads a couple were with the heads ported, and the rest were stock. Tc76/68/.96, and T78/68/1.15(no change between the two) all cams pulled similar past 4K, but the 212/112 lsa cam ran the quickest ET and MPH, and ran the best vs psi of boost. Went 10.31@130mph @ a true 4875lbs, nasty aug DA. Same combo with Garrett GT76/94 ran times in sig. The weight could have something to do with it but mph still is = to power observed. The larger cams did nothing for me except sounded nasty, and took more RPM to launch.
Old 07-11-2012, 03:20 AM
buick_lsx's Avatar
I went with the bigger cam for the sound...I didn't want to be sneaky lol
Quick Reply: Camshaft Recommendations
