Breaking in FI motor
Old 07-12-2012, 08:01 AM
Tirefire's Avatar
Default Breaking in FI motor
I'm about to fire my block up for the first time and was wondering if I should even hook up my D-1 to it. I will not be going over 3000 rpm but needed to know what other people that are FI do when breaking in their motors.
Thanks
Old 07-12-2012, 08:05 AM
LS1NOVA's Avatar
If you can, run it with varying rpm and light loads on the street for a couple hundred miles to break in the rings. Ive taken a fresh 6.0 directly to the chassis dyno for tuning without break in without issues though.
Old 07-12-2012, 08:35 AM
Tirefire's Avatar
Ok thanks but does it matter if the procharger is on it?
Old 07-12-2012, 08:48 AM
LS6 Z28's Avatar
according to the majority on here the consensus is to vary the rpms and lots of engine breaking. Just make sure you get into it hard because the rings break in very quickly and it is imparitive you do this within the first 100-250 miles. If someone disagrees that is there opinion, I also was under the assumption you "baby it" for some many hundred miles before you go wot but many say thats the opposite of what you want to do. I have also done lots of searching and everyones opinion will vary on this topic but again this is the consensus of many people saying get into it decently hard in the beginning vs babying the car.
Old 07-12-2012, 09:20 AM
LS1NOVA's Avatar
Doesnt matter. Basically just dont start it up and go 6500rpm all day right out of the box if you have the choice.
Old 07-12-2012, 09:31 AM
Tirefire's Avatar
So yes blower on or off?? Will having the blower on help break in better?
Old 07-12-2012, 09:32 AM
Tirefire's Avatar
Ok thanks!!
Old 07-12-2012, 09:35 AM
LS1NOVA's Avatar
Put it on. It wont really help break it in "better" but no reason to not install it all at once.
Old 07-12-2012, 09:38 AM
pwrtrip75's Avatar
What is there to break in? Rings break in instantly... Take that thing out and put it to the floor. Engines dont travel miles so thats meaningless.
I thought only ricers "break" stuff in. Seems to be the excuse they all have why they run their mouths and then cant race... lol.
Old 07-12-2012, 09:51 AM
LS1NOVA's Avatar
Perfect example of why these threads are meaningless. Everyone has thier own opinion and what works for them.
91sonomast's Avatar
I'd let it warm up and take it easy for the first few miles. But as said, rings seat almost instantly as long as everything is done correctly, throw the blower on and beat on it.
SPRAYED 01's Avatar
I agree. I let it go through a couple full heat cycles in the first day. Let it get hot,let it cool all the way down. Then its on. I mainly do that for the valve springs.
Probably doesn't make to much of a differance but why not.
Old 07-12-2012, 09:59 AM
LS1NOVA's Avatar
Break in time is not just for the rings. Small air bubbles work themselves out of the cooling system, small particles in the oil that should get changed out before going all out, etc etc.
Old 07-12-2012, 10:47 AM
blue00ZZleeper's Avatar
This is one the automotive worlds greatest debates lol. I agree with what most the others have said and its what I did but once again, its a personal choice. I started my motor...let it idle for about 30 seconds to make sure there were no leaks or major issues and then slowly ran it from about 2K up to 4K and back down varrying rpm. Rings seat quickly under pressure so its important you don't let it idle for to long. I drove it up to my tuner the next am, got it tuned and ran his new 5.0 while my car was still N/A lol. It put down 370rwhp lol I try and change the oil after 100 and then 500 miles to make sure most of the metal particles have been removed. I also used Joe Gibbs break in oil with ZDDP.
Edit: I ran it without the blower but only because I was still waiting on parts. I would have ran it with if I had what I needed.
Old 07-12-2012, 10:57 AM
ICRAZY6's Avatar
When I purchase my engine from AES I had them break it in on their run stand. This way it could be installed and thrown on the dyno without any issues. So far with 4200 miles on the engine and D1SC @ 13psi no problems what so ever.
Old 07-12-2012, 11:09 AM
LS1Tech Sponsor
hellbents10's Avatar
Th most important thing for break in is having a proper tune up. If you are nailing the tune up fast then you should be ruining it just how you want to all the time.
Best thing is to start it up get oil and coolant up to temp and start making pulls with a good tune up, while monitoring everything in a closed environment. Preferably on the engine dyno or on the chassis dyno if the engine dyno is not a choice.
Old 07-12-2012, 11:17 AM
ZNix's Avatar
Throw some boost at it to help seat the rings.
Old 07-12-2012, 11:18 AM
Tirefire's Avatar
That's awesome!! How many more pounds you gonna throw at your block with that D-1? I'm in the same boat right now but I think I'm gettinig an F1a sooner than later...
Old 07-12-2012, 11:23 AM
Tirefire's Avatar
I only got a base line tune (Frost tune) right now I'm hoping to tune it soon though. I have a wide band, fuel pressure and boost gauge so I'll keep an eye on it. I was hoping to get a solid tune after I put about 250 miles on it. Would there be any negative effects if I did this?
Old 07-12-2012, 11:39 AM
pwrtrip75's Avatar
By the time you are done tuning it.... Its well broke in.
Quick Reply: Breaking in FI motor
