turbo exhaust
Old 07-25-2012, 10:08 PM
lsthirdgen's Avatar
Default turbo exhaust
are any of you running with just pipe straight off the turbo? im going to be doing an ls swap in my 87 camaro and im thinking about maybe going turbo later on. i would think the exhaust note would be muffled some by the turbo but how much? this may be a dumb question but i have no experiance with turbos. any input is appriciated. thanks!
Old 07-26-2012, 06:47 AM
1999Black_Z28's Avatar
I'm running just the downpipe dumped after my k-member and it's quieter than my old setup with headers and e-cutout open. It's not quiet but it's tolerable for me...
Old 07-26-2012, 07:34 AM
geoguy1369's Avatar
depends on how loud you like your car. Thats to loud for me but i like quiet cars and i like it when it sounds like a jet in the car
Old 07-26-2012, 09:27 AM
custom 68's Avatar
I have mine open right now and it dumps right below my cab. Well it is pretty loud. probably would be better with a little more pipe length but I need to quiet it down. I am in the search for the "perfect" muffler lol.
Old 07-26-2012, 06:51 PM
lsthirdgen's Avatar
id run open headers on the street if i could get away with it lol. think i could get away with running it out in front of the rear passenger tire without too much attention from the coppers?
Old 07-26-2012, 07:14 PM
tt383lt1's Avatar
i had my two down pipes right off of the turbos straite to the ground it was still loud. i have two magnaflow 4x9 in the front bumper in front of the tires and it is still loud enough to get in trouble when you get on it. also it sounds nice
Old 07-26-2012, 09:28 PM
lsthirdgen's Avatar
do you have pics of this? sounds cool!
Old 07-26-2012, 09:52 PM
tt383lt1's Avatar
here is one i had on my laptop. ill get more. but i have a mufflers right in front of the tires on each side. that exhaust pipe coming out ofthe bumper is actually the muffler.
Old 07-27-2012, 10:09 AM
lsthirdgen's Avatar
Do you street that? I'd think the muffler sticking out in the front bumper might attract some unwanted attention lol. I like the set up though!
Old 07-27-2012, 12:21 PM
black4.8's Avatar
this is all i run and street drive it. not as annoying as thought it would be. sounds bad *** too. has a 6" long schoenfeld muffler in there. exits under passenger door.
Old 07-27-2012, 12:23 PM
black4.8's Avatar
short driving vid
http://youtu.be/86jBm87GbDg
Old 07-27-2012, 03:17 PM
Orr89rocz's Avatar
Depends on the setup.... depends on the heads/cam/compression, turbo size and housing, header collector size and exhaust pipe downpipe size.
My old 401 shortblock at 9 to 1 with mild 195cc heads and baby 233 deg cam, .564" lift breathing thru a hybrid log/header type manifold into a .68 a/r P-trim wheel was fairly quiet with straight 3" down pipes (twin turbo). I just ran bullets on the rear to quiet it down abit more for my liking.
New setup is same shortblock with 245cc heads and a 246 deg .640" cam, .96 a/r housing on the same turbos with new tubular header manifolds this time and same 3" exhaust back. WAY to loud now... ridiculous with open pipes and bullets did not help much. I added 6" round case 14" long dynomax ultraflo's in addition to the bullets just to get car around same volume as it was with old setup. RIDICULOUS how much difference there was.
Old 07-27-2012, 05:34 PM
lsthirdgen's Avatar
Originally Posted by black4.8
short driving vid
damn that sounds pretty good! i think i may try this route
Old 07-30-2012, 06:21 PM
lsthirdgen's Avatar
what turbo do you run? seems like it worked pretty good on the vid. i will be running a 4.8 also
Quick Reply: turbo exhaust
