torn on turbo selection for my 408 build
Old 03-04-2012, 10:57 PM
rubbersdown's Avatar
Default torn on turbo selection for my 408 build
starting to track down parts for a new build and im torn on turbo selection. Gunna be a 6.0l iron block, stroked to 408, all forged internals, dished pistons to give me around 9:0 compression. 317 heads, 100lb injectors, hi ram intake etc etc etc. I want to make around 800-900rwhp on pump gas. I do not go to the track often but id like to be running in the low 10's high 9's when I do. Now I am torn between using TWIN master power p trim 70's with an .81 A/R, or running a larger single, thinking a s488 with a 1.10 A/R or possibly a turbonetic t88. Whats all yalls thoughts on those choices?
Old 03-04-2012, 11:48 PM
konceptracin's Avatar
Gt50-88
Old 03-07-2012, 05:30 PM
well now after a bit more research im thinking of going with the budget garrett gt88 1.23 AR, T6. Its good to 1400hp and should easily cover the 850+ rwhp I want with alot of room to grow. Any thoughts on this turbo or anyone personally use it? I hear its alot smaller (in physical size) than the s488 too which is always good.
Old 03-07-2012, 06:43 PM
Search gt4788 if that's the turbo ur talking about there are a few people with a 408 and that snail
Old 03-07-2012, 06:58 PM
no thats not the same one, I think it may use the same comp housing but thats all
Old 03-07-2012, 07:12 PM
ls2foryou's Avatar
I run a pt88 and it just works ..... With 408 it will spool real nice... 800 900 all day long...
Old 03-08-2012, 12:30 PM
LS1TECH Sponsor
DrTurbo's Avatar
Yes the GT88 and GT91 units are compact and spool very well as do the S400-HP88's. The GT47 is a bigger frame unit indeed. The GT91 would be the one better suited for that motor...850 rwhp and not break a sweat.
Old 03-08-2012, 01:54 PM
thanks for the words of wisdom doc, I know you know your ish so the gt-91 it is. I only want 850rwhp or so for my street driving which will be 99% of what I do, but that one or two times a year I hit the track I want to be able to turn up the boost and make 1000+ rwhp. Im building the motor way overkill with all callies internals to easily handle 1500hp so it shouldnt be a problem. Ill be calling you guys and ordering the 91 when the time comes, hopefully in just a few weeks.
Old 03-08-2012, 02:47 PM
Just out of pure curiosity doc, IF I change my mind and decided to go twins, what twins would you recommend?
Old 09-21-2012, 07:17 AM
baggins's Avatar
what did you decide? almost the same exact ballpark your in
Quick Reply: torn on turbo selection for my 408 build
