Huron Speed Turbo Kits $1999 with Dual Fuel Pump Options now as well!
Old 08-18-2012, 02:56 PM
LS1Tech Sponsor
Superman09's Avatar
Default Huron Speed Turbo Kits $1999 with Dual Fuel Pump Options now as well!
Huron Speed Truck Manifold Turbo Kits: $1999 for the rest of August!
*Now also offering a Dual Intank Fuel Pump option to add as well! This utilizes dual 255lph fuel pumps in a modified bucket all set up with a Hotwire kit! 99-0 ship outright with a new modified bucket. 98 cars require sending in your assembly for modification! These are also on special during this time for only $449
Order Direct from the Website here for the end of August Special:
http://shop.huronspeedproducts.com/F...FBodyTurbo.htm
And for those that have not seen the kits before, here is the information:
Huron Speed 1998-2002 LS1 F-body Truck Manifold Single Turbo Kit
Here it is! Kits are IN STOCK, ZERO wait time on shipping
This kit is MUCH more complete than your run of the mill Truck Manifold kit. Comes with the complete hot-side, cold-side, all couplers, clamps, brackets, flanges, gaskets, etc as you can see from the picture! Kit includes all components to run either the 38mm or 44mm Wastegate, as well as to run a MAF or not!
All piping is made from 321 Stainless, yes 321!
Components:
-2.5" crossover with T4 flange and 38mm Wastegate Flange, dump to atmosphere
-38mm-44mm Wastegate Adapter Flange
-3" Downpipe with 3" V-Band flange (3" V-band on exhaust end also for easy to add on more exhaust)
-3" Cold side piping from turbo to FMIC to Throttle Body
-MAF Delete pipe
-50mm Blow-Off Valve Flange on Cold side piping
-4" core front mount Intercooler
-All exact, specific couplers
-Extra exact couplers to run or not run the MAF Delete
-All exact, specific T-Bolt clamps
-All gaskets
-F-body front mount intercoolers brackets w/ bolts
-F-body alternator relocation brackets
All piping made from 321 stainless steel, fully polished.
Requires Turbo, Wastegate, BOV, Oil Lines, and Truck Manifolds to complete
Being a truck manifold kit, you will lose your A/C
You will have to remove or lower front sway bar
Kit retains factory radiator in factory position, just need to add pusher fans
Kits include what you see in the picture below!
Order Direct from the Website here:
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 08-21-2012, 06:46 AM
LS1Tech Sponsor
Superman09's Avatar
Also have added a turbo style tubular K-member to add as well if interested!
__________________
Old 08-21-2012, 09:27 AM
Boosted Firehawk's Avatar
how much more to add a turbo, bov, wg to that price?
Old 08-21-2012, 10:31 AM
99Z28LS1's Avatar
I'm sure price is dependent on which parts you want
Old 08-21-2012, 11:31 AM
LS1Tech Sponsor
Huron Speed's Avatar
pm sent!
__________________
YOUR SOURCE FOR ALL THINGS TURBO!
CASEY@HURONSPEED.COM
TWITTER @HURONSPEED
Old 08-21-2012, 11:48 AM
LS1Tech Sponsor
Superman09's Avatar
Boosted Firehawk, the on3 turbo and 38mm wg with 50mm bov is 500 extra and can all be added right on the website there with the drop down boxes! Thanks!
Jon
Old 08-21-2012, 11:22 PM
Br1_ss's Avatar
damn i shouldve waited for this deal lol
Old 08-23-2012, 06:36 AM
LS1Tech Sponsor
Superman09's Avatar
Thanks for the orders!
Jon
__________________
Old 08-23-2012, 06:32 PM
02LS1ram's Avatar
I ordered mine yesterday. can't wait to get it!!! hope to have the car on the dyno In a few short weeks
Old 08-23-2012, 09:38 PM
LS1Tech Sponsor
Superman09's Avatar
__________________
Old 08-23-2012, 10:07 PM
SVTconfused's Avatar
you are killing meeee.... lol
Posted from LS1Tech.com App for Android
Old 08-23-2012, 10:10 PM
jsteele90's Avatar
Very nice looking kit
Old 08-24-2012, 09:54 AM
LS1Tech Sponsor
Its just a couple small clicks and a bout a weeks wait from being on your doorstep!
thank you very much! we appreciate it.
__________________
TWITTER @HURONSPEED
Old 08-24-2012, 11:02 AM
Somebody09's Avatar
Is your twin fuel pump setup available separately? And any pics?
Old 08-24-2012, 07:18 PM
LS1Tech Sponsor
Superman09's Avatar
Thanks guys!
__________________
Old 08-24-2012, 07:20 PM
LS1Tech Sponsor
Superman09's Avatar
Absolutely, you can check it out and order direct from the website here:
http://shop.huronspeedproducts.com/D...er-DblPmpr.htm
__________________
Old 08-24-2012, 07:42 PM
HAHAHA.... Yes... small clicks... but small things are expensive...
Old 08-25-2012, 05:37 PM
LS1Tech Sponsor
Superman09's Avatar
__________________
Old 08-28-2012, 10:17 PM
LS1Tech Sponsor
Superman09's Avatar
__________________
Old 08-29-2012, 11:58 AM
GreatWhiteZ28's Avatar
do you sell just the pipe work?
Quick Reply: Huron Speed Turbo Kits $1999 with Dual Fuel Pump Options now as well!
