whos running a boosted 408?
Old 09-05-2012, 03:18 PM
GreatWhiteZ28's Avatar
Default whos running a boosted 408?
just wondering who's running a Boosted 408, I know they are out there, since I'm building mine, I'd like to see the different setups and get a general Idea, I'm leaning towards running the S400SX-75, 83mm with 1.10 A/R.... not looking to make the most power on the boards, just trying to keep it pretty tame for longevity and possibly go bigger later on down the road once I open up some room and get some other stuff out of the way.
Old 09-05-2012, 09:28 PM
js2fst's Avatar
Automagic has a sweet one
Old 09-05-2012, 09:37 PM
Cam72aro's Avatar
I have a 408 in my t/a with a gt91 on it on a t6 housing. What are the specs on the s400sx-75? If you want to check my build the link is in my sig plus I am local to you so you could see it in person.
Old 09-05-2012, 10:39 PM
tim99ws6's Avatar
I run a boosted 408...
Old 09-06-2012, 04:30 AM
StreetSilverado's Avatar
Procharged 410CI here......it runs ok on just 12lbs so far.
Old 09-06-2012, 08:06 AM
scooter k's Avatar
I'm running a 408 and GT91 on 21psi!
Old 09-06-2012, 10:48 AM
Pat-Man's Avatar
Boosted 408 on a T76. While it has instant spool, its a dog in the top end due to backpressue. I inherited this build, so as soon as I get the money I'll be going with a GT-91.
Old 09-06-2012, 12:34 PM
only thing I can find for the specs on the s400sx-75 on the one I'm looking at has a 83mm Turbine wheel with a 1.10 A/R Ratio....I'm still learning about how read Turbos and such, just kinda teaching my self and reading threads on here when I can.
Old 09-06-2012, 12:52 PM
Cam72aro's Avatar
I would go much bigger on the turbine. Mine has a 94mm turbine. Talk to Dr. Turbo and he will probably recommend the same gt91 that I have.
Old 09-06-2012, 01:05 PM
they have a wide range of turbine wheel sizes to choose from, ranging from 83mm to 96mm on the turbine wheel sizes....in another thread he had mentioned this turbo for it's faster spool time, and made the same power and a little less PSi..
Old 09-07-2012, 11:33 AM
OT woul it be a better choice to build a 370 instead of a 408? I'm at the point now where all I need before the shortblock is done is the crank, will do a 370 of it would be better for boost in the longevity department.
Old 09-07-2012, 11:52 AM
wrp
wrp's Avatar
4.0 Liter Whipple on a 408 with ETP 245 heads, -.28cc dished pistons, Eagle Crank, built by TSP. Running E85 on 221 lb ID/Bosch Injectors. Makes 23 lbs of boost, 1000 ft lbs of Torque at 2500 RPM
Old 09-07-2012, 12:58 PM
Turbo2L's Avatar
A T4 with an 83mm turbine will choke up that big cube motor very early in the power band and you'll be very disappointed. I'd at least go with a T6 80mm with the 1.32 housing. It will make much more power and spool quickly. It seems like a big turbo, but it's nothing a 6.6L can't light off. Best of luck.
Old 09-07-2012, 01:01 PM
LS1Tech Sponsor
hellbents10's Avatar
The 83mm turbine gets choked up pretty quick on even a 370, I would opt for the 96mm turbine.
Old 09-07-2012, 04:35 PM
TurboS10's Avatar
370 with a S480 96mm T6 1.32 will work for you and is pretty cheap. Easy to sell later.
The 83 turbine is a better match to a 5.3 or 5.7 with low rpm.
Old 09-07-2012, 06:39 PM
Thanks for the actuall input guys, always nice when members are helpful rather than dicks with smart *** comments that don't help, but it looks like I'll go with the 96mm turbine on the T6 flange once the shortblock is complete, hopefully it will be in the shop for wiring in December, and hopefully make it out to the next TX2k event, but that's a long shot in the dark right now.(unless I win the lotto or something)
Old 09-07-2012, 09:38 PM
cmac06's Avatar
Running (will be) with twin Garrett GTX3076. Should be pretty quick spooling. Only shooting for around 700 on e85.
Old 09-08-2012, 07:49 PM
SUPERMAN_00TA's Avatar
I'm was running 408 with a F1a procharger.... I'm in the process of a gt91 turbo build. 1.08ar on the turbo.
Old 09-08-2012, 09:19 PM
TurboMark8's Avatar
why arent people running dual wastegates to reduce the choking up on the top end? Run 2 gates: one referenced off boost pressure, the other off of drive pressure.
Old 09-08-2012, 09:53 PM
Cam72aro's Avatar
I am running a single 66mm precision referenced from compressor housing.
Quick Reply: whos running a boosted 408?
