how much boost can a stock ls1 handle
I have a ls1 with 90k on motor im about to put on a rear mount turbo how much boost can it take all stock ls1 no mods. and keep it as a dailydriver
i think you should do a bunch more research as much as its probably painful to hear me say that.
its gunna take more parts or some compromises on your stand with all stock stuff, some things might have to get swapped out, or ultimately i think the price paid and the horsepower gained might not be worth it, if you understand what i am saying
unless you want a turbo just because it makes turbo noises.
some people are like that too lol
Tenured Member
Boost is a measure of restriction.
How much power do you want to make and how long do
you want it to last? That is the question.
Stock LS rods are the weak link. If the tune up is spot on it will last for a while @ 500-600rwhp UNDER 6500rpm.
I've pushed 800rwhp using an older style LS rod.......but it was short lived.
Ok well I definitely do not want to blow my motor. I want to play it safe and make a good 450hp with a super good tune I dont want to push more then 5psi. Will need to mess with fuel sorse?
I'm building my own turbo. I'm using a Cummins turbo diesel. The hx35w I'm going to use a external waste gate with no intercoler. What do u guys think
The following users liked this post:
David Hyde (09-15-2020)
Heads and cam will run me like 2k and I still have to put them on my self and get it tuned. I got a rear mount for under 1k and I cud slap it on in a weekend. Is it worth it? I have been thinking of heads and cam but Iv been wanting a turboed car.
http://forums.corvetteforum.com/1581720606-post26.html
This is my friends 99 FRC, stock ls1 with a tti kit on it. This is not a friendly dyno either. He went 10.5x @ 141 Saturday night. It has around 80k miles on it.
if you want it to last, 6psi, a really good tune, and nice and rich or in the safe zone with fueling and spark. Don't dump the clutch and don't beat on it bad, or else those factory parts won't last.
if you keep it a fun daily driver and put some good parts with that rear mount it will last.
check out my build in my signature.
You can push 7-9 psi safely with these 2 components and be closer to 500-550 rwhp.... my opinion.
Fuel... if you do the Racetronix Hot Wire kit, you may be ok on fuel, but should replace injectors with 60lb injectors.
LS1Tech Sponsor
https://ls1tech.com/forums/dynamomet...786+rwhp+stock
786 rwhp, stock bottom end. Car ran like that for months before he tore it down to build a fuel system (snowballed from there )
We were running out of fuel up top, so its likely the early shifts that kept it together that long, rarely if ever saw anything past 6000 RPM.
you are not asking quite the correct question, or you are leaving out a great deal of details.
im in the same boat as you, i got a decent deal on a brand new full sts kit. i was just going to bolt on and go, but after reading quite a few build threads im finding that stock parts only last so long. i put the project on hold and started collecting parts. i picked up a set of 317 heads, intercooler, piping, now im starting to look into internal parts. if you can spend more and build the motor i think you'll be better in the long run.
at the least get fuel injectors, fuel pump and rewire kit, spark plugs, and make sure your tuner is familiar with turbo'd ls1's
