Standard rotation v reverse rotation...
Old 10-19-2012, 05:55 PM
rp0029's Avatar
Default Standard rotation v reverse rotation...
I have a 68 camaro w an lq4. I want a pro charger, but will have to fab my own kit. Do I need a reverse rotation head unit? What is the difference?
Old 10-19-2012, 06:20 PM
427's Avatar
Assuming your using a belt drive unit the way the air enters the supercharger will dictate forward or reverse drive. If the air entry faces backwards (rear of car) you need standard rotation. If the air enters from the front of the car you need reverse rotation.
If you run a gear drive from Blower shop or Alston you need a standard rotation unit.
Kurt
Old 10-19-2012, 07:31 PM
js2fst's Avatar
I would reverse rotation and modify the hat maybe and piping of intercooler but at least the belts would line up easy. How much power do you want?
Old 10-19-2012, 07:48 PM
rp0029's Avatar
Those Alston units look great! I imagine they are pricey though. I'm only making about 320 to the wheels now. Car is lq4 w/ls3 top end, 222/230 .570 lift cam, through a very heavy drivetrain. 500 rwhp would be awesome.
Old 10-19-2012, 07:56 PM
js2fst's Avatar
A p-1sc will do that easy probably more like 600 the Alston bracket is pricey a 8 rib will get you there easy but look at a aster bracket if you go higher.
Old 10-19-2012, 10:59 PM
rp0029's Avatar
The problem is that I can't mount my alternator down low. It hits the frame. I think this precludes the Aster. Any bracket options that will mount the head unit at the top/passenger side?
Old 10-20-2012, 11:05 AM
LS1TECH Sponsor
Lonnies Performance's Avatar
C5 & C6 Vettes mount at the top passenger side & use reverse rotation chargers.
Check them out for ideas.
Old 10-20-2012, 11:49 AM
stevieturbo's Avatar
If you mount the blower with the inlet facing forwards it will be reverse rotation
If you mount it facing rearwards it will be clockwise.
It's entirely up to you and space available which you opt for
Old 10-21-2012, 06:39 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
If you want to see any of the installation instructions for the ProCharger kits, send me an e-mail to brutespeed@gmail.com and tell me which ones you want me to e-mail. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 10-21-2012, 06:44 AM
LS1Tech Sponsor
http://shop.brutespeed.com/ATI-1LS10...S100-D1SCI.htm
The ProCharger Transplant kit was designed to work in the 1st gen f body. Bob
__________________
Old 11-18-2014, 04:19 PM
camaro427-69's Avatar
older thread but maybe this helps if anybody ever searches for something similar.....i´m doing the same setup right now and i used a reverse rotation C5 kit cause i already had the corvette acessorys and with the c5 kit i had not to deal with any alternator issues. my stuff came from pace performance and was one of the non A/C special setups they sell. with the reverse rotation it is a no brainer and you don´t have to get brackets or move the alternator.
Old 08-03-2016, 01:42 AM
T/A KID's Avatar
edit....
Old 08-03-2016, 01:46 AM
T/A KID's Avatar
Edit 2x
Old 08-03-2016, 04:48 AM
LS1Tech Sponsor
Originally Posted by T/A KID
edit....
I sent you a pm. Thanks. Bob
__________________
Quick Reply: Standard rotation v reverse rotation...
