Got my KUP water vapor system hooked up, no retune time!!
Finally got the time to hook up my Kurt Urban water vapor system. Its a very nice piece and a nescesity in my opinion for anyone making decent power that already had their rear steam ports blocked off. The car is a 99 SS M6 with a 9 inch. It has the typical full boltons, custom blower cam and a D1 procharger kit with front mount. The car is tuned now albeit not very well in my opion. It drives like pure crap. It made good power at 581/524 at 10.5# peak boost with the 4.25 blower pully on its current tune. I am dropping it off with Jonathon at Tick Performance Saturday to see what he can do with the tune and maybe turn it up a little . It is still stock bottom end so I don't think he will go too crazy with it but I trust his descision either way. I will keep you guys posted with results. I expect nothing from the best from them as always.
Is that that heat protectant split loom, it has tape style holding? I just used some of that on my starter wires as my header heat was melting the standard plastic loom. Why needed on that line?
It was recommended to help flow from Kurt and others on the board. not sure if that is true or not, but I had to either run it over or under my trans fluid dip stick so I wacked the bracket with a hammer so that it would go over the stick.
