denmah's commonly bought turbo car items (update 7-11-16)
#43
but yes i used these injectors in my friends firebird and in the other turbo silverado we built.
#44
hope you dont mind, heres a few more
modular turbo's oil feed block
http://vtsql.gkvbf.servertrust.com/L...ck-p/cbr02.htm
alt relocation bracket
http://vtsql.gkvbf.servertrust.com/C...it-p/cbr01.htm
amazon has eboost 2 for $479
twin in tank pumps
http://www.airpowersystems.com/fbody...sgmf-fss01.htm
http://www.lonniesperformance.com/fbodyfuelsystems.htm
https://ls1tech.com/forums/fueling-i...ick-cheap.html
twin in tank pumps
#48
like obd2 v6 buicks, supercharged regal... should be one of them, literally every ob2 3800 series 2 v6 even like, 99-04 blazers have em, you can just pull the sensor out of the airbox piping its rubber, the sesnor is short and hard plastic, cut the IAT wires far back closed to the throttle to get more wiring
#50
ill add to it
ebay catch can that i have
http://www.ebay.com/itm/BLEMISHED-Ba...vxp=mtr&_uhb=1
blow off valve
http://www.ebay.com/itm/EMUSA-50mm-B...vxp=mtr&_uhb=1
WASTEGATE
http://www.ebay.com/itm/EMUSA-38mm-W...vxp=mtr&_uhb=1
blow off valve
WASTEGATE
#56
Is that the one that is straight cut gears (or whatever they are correctly called in a pump like this), and is quite noisy?
#58
yes sarg is right shes a noisy bitch lol but so is my bosch 044 so i dont really care. once the truck is running all that sound basically goes away so its not a big deal. it worked out good i had it hooked to a switch so i turned it on before i started the truck and just let it run until i shut the truck off. i used -8an (1/2") lines because since it sucked out all the oil i didnt need to go with a huge drain line
#59
I wanna help some too... duel gss340 and 341 KIT with Yfitting etc. 219 bucks! not bad
http://www.sho-mespeed.com/index.php...ry_pathway=629
#60
Matt or anybody who might know.. is there a radiator that summit already has dual pass with the inlet and outlets on the passenger side already? or is that one I have to get a welding shop to mod?
