TU1 cam for this setup? If not then what?
Old 04-17-2013, 02:57 PM
MonmouthCtyLS7's Avatar
Default TU1 cam for this setup? If not then what?
Would like something w/ a decent lope, setup will be
5.3 LM7, hand ported 243's, Magnum T76. Turbo specs are...
Compressor
-506Trim Inducer Wheel
.80 A/R w/ 4"(101.7mm) inlet and 2.5"(64mm) outlet
Turbine
-76 Trim Exducer Wheel (P-Trim)
.96 A/R TURBINE HOUSING w/ standard T4 undivided Inlet and an 3" v-band outlet
Old 04-17-2013, 04:25 PM
qqwqeqwrqwqtq's Avatar
It's not what you're asking but IMO spending the money on any cam with this combo is a waste as you would be better off with the stock cam and a better turbo.
Old 04-17-2013, 04:27 PM
HRHohio's Avatar
Another option is Tick Performance Turbo Stage 1 cam. It's:
Turbo Stage I 226 226 .60x .60x 114+3
Compared to Speed Inc's TU1:
TU1 225 225 .581 .581 113
It has a little more lift and duration and similar LSA.
Either are good grinds. What are your hp/boost goals? Keeping it stock bottom?
Old 04-17-2013, 04:42 PM
TU1 226 226 .60x .60x 114+3
I meant the tick perf. TU1 lmao, wasn't aware there was 2 cams w/ the same name...Id like to see 650-700 rwhp through a A4...stock bottom w/ Arp stuff...
Old 04-17-2013, 04:47 PM
LS5.3stang's Avatar
on3 76mm has 65mm exhaust turbine motor will choke . for reference master power 76mm has 68mm exhuast. your car will have crazy backpressure .
Old 04-17-2013, 04:49 PM
I have a LM1, was also going to run a cutout.
Old 04-17-2013, 04:59 PM
What's wrong w/ that turbo? What would you recommend at a similar price S475?
Old 04-17-2013, 05:04 PM
LS5.3stang's Avatar
wow missed the Magnum part , it has a 64.5 mm exhaust (p trim )(q trim 67mm) , i would buy the gt45 80mm or 76mm from VSracing both have 77mm exhaust turbine
Old 04-17-2013, 05:08 PM
HRHohio's Avatar
Whoops... lol damn copy paste... forgot to change the TU1 to "Tick Turbo Stage I" on the paste (pasted so formatting would be the same... ) lol You know what I mean though...
So which are you asking about Speed Inc or Tick? Specs are correct... I hope! LOL
Old 04-17-2013, 05:23 PM
The Tick TU1 lol
Old 04-17-2013, 05:48 PM
I'm liking the GT45 80mm, what kind of power is she capable of?
Old 04-17-2013, 06:55 PM
LS5.3stang's Avatar
i dont think anyone has maxed this turbo out yet.it will definitely make more power than the magnum t76 that is a very old design.(uses the TO4 housing) denmah put one on a 6.0 in a truck here is the tread
https://ls1tech.com/forums/forced-in...ires-haha.html
Old 04-17-2013, 07:16 PM
Nice........
Old 04-19-2013, 01:13 PM
Sales@Tick's Avatar
With a 5.3 drive pressure will obviously be less than that of a LS1 with that turbo, but I'm with Jim I'd rather see you use something better with a larger turbine wheel.
Then you'll have some room to get some overlap out of the cam profile without choking the thing worse than it would already be choked with that turbine wheel and a cam with enough overlap to get the lope that you want.
If you want some lope you could go with our 226/235 .605"/.610" 114+3 which is "classified" as a LS3 Stage 1 turbo cam, but it would work fine with your set-up and a GT45 or anything with a decent sized turbine wheel.
Quick Reply: TU1 cam for this setup? If not then what?
