Build thread: 5.3/twin 66mm/megasquirt3
Old 10-07-2013, 10:02 PM
  #41
vinnysnova's Avatar
got some more done. Does anyone have a startup tune for megasquirt3 on e-85? I am real close to lighting the fuse on this bomb!
Attached Thumbnails Build thread: 5.3/twin 66mm/megasquirt3-coilbrac.jpg   Build thread: 5.3/twin 66mm/megasquirt3-mountedcoils.jpg   Build thread: 5.3/twin 66mm/megasquirt3-mountedcoilsright.jpg   Build thread: 5.3/twin 66mm/megasquirt3-2013-10-05_19-31-20_772.jpg   Build thread: 5.3/twin 66mm/megasquirt3-fuel-lines.jpg
Old 10-08-2013, 12:48 AM
  #42
Moderator
denmah's Avatar
i would ask cameron vic for the one he uses in his turbo 5.3
and modify it
Old 10-08-2013, 06:14 AM
  #43
Smallblockguy's Avatar
There is a ve table generator in tuner studio.
Old 10-09-2013, 03:50 PM
  #44
Reject's Avatar
nice set up!
Old 10-09-2013, 04:55 PM
  #45
Compressor Surge's Avatar
Originally Posted by denmah
and modify it
LOL
I am using an MS3x and micro for trans control.
Works pretty well, but I'm having problems with the VSS dropping out once in awhile. Causes the converter to unlock and sometimes it drops a gear or two.
I've also had a random pop/stumle/break up in boost that i'm still trying to track down...this MS3 has been a test of patience. Been screwing with it since April. Hopefully yours goes smoother. Sick build.
Old 10-13-2013, 11:48 PM
  #46
vinnysnova's Avatar
Got a video of the first try to fire it. o2's not hooked up yet but it ran!
https://www.facebook.com/photo.php?v...08996852079427
Old 10-22-2013, 07:10 PM
  #47
vinnysnova's Avatar
Running better, need some more tune time. Now get converter in and wire up the microsquirt and build a driveshaft and go for a drive!!!
Old 10-22-2013, 07:44 PM
  #48
Reject's Avatar
were you able to figure out the issue with the PCM? can't wait to see the burn out vids!
Old 11-25-2013, 10:01 PM
  #49
vinnysnova's Avatar
Got it on driving, now for more tuning. Here is a pic and a vid link of a flyby, still spinnin going by the camera. Hope some 325/50/15 m/t's help!
Attached Thumbnails Build thread: 5.3/twin 66mm/megasquirt3-2013-11-18_15-24-08_670.jpg
Old 11-26-2013, 02:43 AM
  #50
Moderator
denmah's Avatar
nice!
Old 11-26-2013, 02:49 AM
  #51
LS1rob00's Avatar
Sweet build! Need some tires for sure, don't want to be putting that thing into a cornfield . Car is definitely going to roll out once it hooks!
Old 11-26-2013, 07:19 AM
  #52
00Wildcat's Avatar
Nice! Much like my first Chevy II 2 build that never got finished because of life. I hope we can meet up sometime. You'll enjoy the turbo 5.3, I wouldn't take it out until I broke it. Chris with the silver S10 has been 8.52 with a 5.3 and out of the box 366 Borg Warners.
Old 04-26-2014, 10:50 AM
  #53
vinnysnova's Avatar
Default update
Car is running good! Got the 325 M/T DR's on it and they hook great, 90mph in the 1/8th at a local street race. The only problem is it needs a higher stall, 2200 is not enough. It leaves with .2lbs of boost and slowly walks out about 100 foot then starts to pull....(like a freight train) The logs look like a 3200 would be about rite.
Attached Thumbnails Build thread: 5.3/twin 66mm/megasquirt3-nova-017.jpg
Old 07-20-2014, 09:51 AM
  #54
vinnysnova's Avatar
Went to the track and ran a:
2.05 60'
10.906@139.92mph
I am only at 1lb of boost at launch, needs a 4000-4500 stall, but it starts to move about 200' out.
Old 07-20-2014, 10:34 AM
  #55
gui67's Avatar
Very nice car.
I nearly have the same setupp: 5.3, turbo, E85, Z06 cam, MS3X, 4L80, MSGPIO
What do you use for thans controler finally: µsquirt or MSGPIO?
I would be interrested by your msq, to compare timing. Is it possible for you to sent it?
Old 07-21-2014, 09:04 AM
  #56
rkreigh's Avatar
Originally Posted by atomic 6
I have been using a microsquirt for a trans controller on the 4l80e, for the last 4 years. As have a few others, but not as long.
http://www.msextra.com/forums/viewto...30663&start=60
The GPIO has more "features" but I started using the Microsquirt before the GPIO was "ready" and the microsquirt seems to be enough to get the job done.
And, has been fool-proof so far.
+1 for the Microsquirt, here.
does this take 2 megasquirt ecm to do the job, 1 for engine management, 1 for the tranny, or can one megasquirt control BOTH the engine and tranny
like to get into the megasquirt world more heavily, it looks like a really good solution.
Old 07-21-2014, 04:18 PM
  #57
vinnysnova's Avatar
Gui67, I will try to get the MSQ sent to u tonight, just look it over first and make sure you want to use it. I ended up using a tci ez-tcu for the tranny, (kinda feel like a traitor)
Quick Reply: Build thread: 5.3/twin 66mm/megasquirt3
