Flexplate for 80e??
Old 09-09-2013, 07:27 PM
allout06's Avatar
Default Flexplate for 80e??
Going to an 80e from a T56, and i need a flexplate. Which one should I get? I was trying to get one from summit because i can get a decent discount on them.. i was looking at this one
http://www.summitracing.com/parts/hu...make/chevrolet
Do you have to an a trans specific flexplate, ie 80e flex plate vs a 60e flexplate? need a quick answer. thanks!
1000rwhp street car
Old 09-09-2013, 07:51 PM
+badss+'s Avatar
Are you using a 6.0 crank from pre 01 engine?
Old 09-09-2013, 08:09 PM
allout06's Avatar
its a callies crank. AES 390. 6.0L block
same **** you got lol
Old 09-09-2013, 08:37 PM
jjcamaro02's Avatar
This should be what you need.
http://www.summitracing.com/parts/tci-399754
Old 09-09-2013, 08:56 PM
allout06's Avatar
I read with that one your stock with a stock sized 4l80e converter though. Ill prolly b running a 10" PTC or Pro torque converter.
Old 09-09-2013, 09:41 PM
00duvall's Avatar
Herrs the one i got J W Performance 93019LSD The Wheel Dished Flexplate
LS1-LS7 (P/G, TH350/400/700-R4, 4L60E/70E/80E)
Bolt Patterns: 10.75", 11.08", 11.5"
Requires .400 longer Torque Converter pilot 212$ shipped. When u have u converter made get the converter pilot .400 longer no spacer
Old 09-09-2013, 10:19 PM
+badss+'s Avatar
I'm using the tci plate
Old 09-10-2013, 07:30 AM
allout06's Avatar
ill look into that one
This one? What size and type of converter are you using??
Old 09-10-2013, 07:39 AM
allout06's Avatar
Link? I found it on summit and its $261
Old 09-10-2013, 08:28 AM
35thsscamaro02's Avatar
Going from the t56 to 4l80 has been one of the best decisions I've made . :-)
Old 09-10-2013, 10:04 AM
allout06's Avatar
I bet it is. Lol. Just gotta figure out this flexplate dilemma.
Old 09-10-2013, 12:18 PM
Capricio's Avatar
Having just bought a new TC from Yank for an 80 conversion, you can take two routes. You can buy a 60 style 3 bolt flexplate and have your TC builder make your new 80 TC come with that style mounting. This doesn't require any doesn't require any curved plate spacers or anything special.
Or, you can get a truck style curved plate, 6 bolt mounting, spacer required. The only advantage to this is that it allows for larger diameter TCs, like the ones found in trucks. Yank will only use the larger TC housings for their multi-disk units.
I went with their Pro-Yank single disk so it will work with the Hughes SFI plate that I used with my 60. Yank, Vig, Circle D, and probably others all can make 80 TCs that will mount on a 60 style plate.
https://ls1tech.com/forums/automatic...ate-4l80e.html
https://ls1tech.com/forums/automatic...l80e-swap.html
Bottom line, if you don't need a giant multidisk TC and aren't using a stock truck TC, stick with the 3 bolt 60 style plate.
Old 09-10-2013, 02:05 PM
00duvall's Avatar
sent u a pm where to get the flex plate
Quick Reply: Flexplate for 80e??
