settings in HPtuners for timing on transbrake
What numbers do I need to put in the below tables to be able to run the in drive spark table on the trans brake and switch to the main spark table once the vehicle moves? The nomenclature for the tables has me confused.
Min TPS %
TPS hst%
max speed mph
speed hst mph
Min TPS %
TPS hst%
max speed mph
speed hst mph
I should say the information was most likely correct just understanding how the tables work has me confused.
For example min tps table says it's the throttle position required to disable main spark table, don't understand what that has to do with in drive spark table, should it just be correlated to vehicle speed? Car not moving in drive spark table, car moving main spark table?
I'm sorry it doesn't work at 100% tps. Does it stay in the idle cells if you are at 99%? I use it with a 6 speed so I wonder if the auto guys have a park / neutral safety switch that is kicking it back into the main table? The wording on some of the table descriptions make no sense at all but the min tps table is what % it takes to disable the idle tables.
