turbo 5.3 s2000
turbo 5.3 s2000
i got a 2010 5.3 all alum bone stock on a 75mm t6 borgwarner turbo tru a powerglide and 308 rear end. the car made 680@17psi on e85 . track it and we got it to run 9.57@144. coud this b the fastes i could get it to run bone stock it felt as i did not have power after 6k. what should my firts mods b
Swapping cams should give you more power above 6k. The truck cams are pretty small and geared towards torque and low end power obviously. Even just an LS6 cam would yield great results.
Or a custom turbo cam if you want some lope with it.
Side note: 9.57@144 is damn respectable for 680rwhp! Shows that the whole system is working good together. Many others have gone slower with more hp. Good job!
