vacuum for brake booster
Old 10-03-2013, 07:58 PM
dmaxvaz's Avatar
Default vacuum for brake booster
Hey turbo guys, I was wondering what you guys do with boost entering the brake booster? Do I need to install a check valve in the tube from the intake to the booster? i have weird brakes now on my trailblazer ss since the built motor/turbo went in.
Old 10-03-2013, 08:07 PM
Twin turbo c5's Avatar
I've never used anything on my turbo cars. My brakes have always worked fine with the stock check valve in the booster. Did you change the cam ? Maybe it's not making enough vacuum.
Old 10-03-2013, 08:20 PM
dmaxvaz's Avatar
it has a .605/.608 lift cam with 110 or 109 centerline, a cam that AES spec'd with my motor. it has brakes, then doesnt. its not constant.
Old 10-03-2013, 09:22 PM
Do you have a vacuum gauge? How many inches of vacuum is that cam pulling.
Old 10-03-2013, 09:25 PM
dmaxvaz's Avatar
12-13 in/hg. sometimes 15 for a second
Old 10-03-2013, 10:55 PM
97WS6SCharged's Avatar
That should be enough vacuum for the power brakes to function. Have you tried bleeding the system?
Old 10-03-2013, 11:19 PM
dmaxvaz's Avatar
i never opened up the brake system, and was fine before the motor/turbo. the brake booster just does not recover fast enough after several brake applications.
Old 10-04-2013, 01:37 PM
1320king's Avatar
I always run a 1 way check valve on my setups. You might need a vaccum canister. I had to run one on my SBC that had a large cam and had the same issues. Pump it 2 or 3 times then it would drop almost to the floor with no pressure. I actualy still have that canister if you need one.
Quick Reply: vacuum for brake booster
