Wastegate advice needed (pics inside)
I have been shaking down a new setup. I have a boost creep problem. I pulled the spring out of the gate and still make 5psi and climbing @6000rpm. I figured the gate would work where I put it but lack of back pressure is screwing that. I need some input on the best of my options. I attached some pics, #1 is the current config., #2 is the easiest solution (tilting the gate on a steeper angle and making a long blend into the cross over pipe), #3 is most likely the best location but puts the gate really close the the ground. Lets hear what you think.??
5.3 w/317's, tick turbo cam and head studs
pt76gts, truck mani's, 2" primaries into a 2.5" t4 merge
tial v44 gate
3.5" down pipe, 3 bullet mufflers run to the rear end and dumped
tial v44 gate
I would go with the number 2 position, having the wastegate pipe as close to a 45* angle as possible. The gate itself wouldn't need to be exactly where it's pictured. It's more important to have the pipe with the angle of flow and put the gate where it fits best. Think of exhaust as water and how it would flow best.
