Datsun 280z Turbo Build - 5.3 / T7875 / Magnum T56 - Video on page 12!
Old 01-23-2014, 01:12 PM
  #61
oscs's Avatar
Post a link, Ive been debating on a new one. Im not sure if the one I have will do the job with a big treadstone in front of it.
Old 01-23-2014, 07:02 PM
  #62
STEEPSS's Avatar
www.Howeracing.com
go to the custom radiator form, and it will give you the list of core sizes and options.
Mine was less than $275!
Old 01-23-2014, 08:17 PM
  #63
oscs's Avatar
Originally Posted by STEEPSS
www.Howeracing.com
Yeah there is quite a bit to choose from. Ill drop him an email
Old 02-05-2014, 09:27 AM
  #64
STEEPSS's Avatar
Well the 4" was just not going to fit easily, so I picked up some 3.5", and got the DP out past the bellhousing. Welds are kinda crappy on some of it as I was at the end of the tank of gas.
Still trying to decide if I want to dump the wastegate or just route it back in.
Thoughts?
Old 02-05-2014, 09:46 AM
  #65
RedRocketZ28's Avatar
Dump it. Won't matter anyway when you pin it shut!
Old 02-05-2014, 10:51 AM
  #66
ShredSled's Avatar
I say route it back in so it won't sound shitty, then just get an ecutout for when you actually want to make some more noise!
Old 02-05-2014, 12:05 PM
  #67
oscs's Avatar
Route it back in. Last thing you want is excess noise and fumes when your on the street cruising
Old 02-05-2014, 12:11 PM
  #68
Excess noise and fumes, hilarious. His car was insane before, ha.
Old 02-05-2014, 12:29 PM
  #69
oscs's Avatar
Yeah it was and it wasn't done half *** like dumping the wastegate in the engine bay instead of taking the time to route it back into the exhuast. Don't slack steep! Do it right you'll be happy you did!
Old 02-05-2014, 01:03 PM
  #70
Since when is it half *** to not route it back in? It's called "personal preference". It's neither right nor wrong. My post about dumping it was a joke anyway. You make it sound like it's ridiculously loud and annoying if it's dumped though. Once again, personal preference.
Old 02-05-2014, 01:29 PM
  #71
rotary1307cc's Avatar
Lol . Fumes while cruising
The gate is only open under boost
Old 02-05-2014, 01:57 PM
  #72
Forcefed86's Avatar
Unless you buy your gate from china... Then they are slightly open all the time.
Old 02-05-2014, 03:27 PM
  #73
oscs's Avatar
Maybe it came off wrong I just think it is much cleaner routed back in. All the cars/trucks I have been around always have it routed back in. I rode in a civic with one dumped it was loud and ostunk of exhuast fumes. Guess there could have been other issues..
When my gate opens on my 7.3 it is LOUD and it's routed back through the exhuast. I couldn't imagine an LS motor although I've never heard one dumped
  #74
oscs's Avatar
Lol . Fumes while cruising The gate is only open under boost
Have you seen this guy drive? Lol it's always going to be open
Old 02-05-2014, 03:31 PM
  #75
STEEPSS's Avatar
Hahahaha
Its not going to take much to route it back in if I decide to go that way.
I'm really more worried about tieing the two frame rails back together in some manner.
I suppose I could just get a piece of 2" and weld it between them, behind the radiator, but I was really hoping to find a cleaner alternative that still helped with structural integrity. I'd love to have a tubing bender - I'd make something swoopy and pretty.... but I don't.
Old 02-05-2014, 03:34 PM
  #76
oscs's Avatar
Hahahaha Its not going to take much to route it back in if I decide to go that way. I'm really more worried about tieing the two frame rails back together in some manner. I suppose I could just get a piece of 2" and weld it between them, behind the radiator, but I was really hoping to find a cleaner alternative that still helped with structural integrity. I'd love to have a tubing bender - I'd make something swoopy and pretty.... but I don't.
I used square tube to tie mine together. No biggy, look fine.
Old 02-05-2014, 03:47 PM
  #77
STEEPSS's Avatar
I'm just not sure how far back I'll have to go to clear the E Fan, and not run into the hot side. Also, I need to devise a way to mount the bottom of the radiator
Old 02-05-2014, 04:18 PM
  #78
oscs's Avatar
Yup mine is pretty far back. If I can fit two turbos you'll be ok. I used the old lower radiator mount that everyone else uses. Lay some rubber strips for cushion and call it a day.
Old 02-05-2014, 05:05 PM
  #79
FlashLCD33's Avatar
Those mounts you posted are legit. I think I'm gonna order some now
Old 02-06-2014, 07:04 AM
  #80
STEEPSS's Avatar
Got a little done last night despite spending an hour and a half snowblowing
Hot side painted
And wrapped. Just cheapo black FG wrap from siliconeintakes.com. Double wrapped with 50% overlap on crossover. Used 50' of 1" on the one manifold, need to buy more.
Quick Reply: Datsun 280z Turbo Build - 5.3 / T7875 / Magnum T56 - Video on page 12!
