Any one use the 1300hp thread stone IC?
Old 11-20-2013, 09:43 PM
SPRAYED 01's Avatar
Default Any one use the 1300hp thread stone IC?
http://www.treadstoneperformance.com/product.phtml?p=485&cat_key=63&prodname=TRV259+Ser ies+Intercooler++1300HP
Any actual experience with this? Im thinking about replacing my cx ebay ic that's loosing 5.5psi through it but don't want to have to di it again.
Alex
Old 11-20-2013, 09:47 PM
rotary1307cc's Avatar
It will be much better than the horizontal you have now for pressure drop
Old 11-20-2013, 09:50 PM
SPRAYED 01's Avatar
I'm sure it will be, just wanted to hear some results. Right now il go from ambient to about 160 at the end of a quarter mile. 5.5 drop at 20psi intake pressure.
Now if this thread stone is only going to do alittle better Il leave it alone. But if i can get a 1-2psi drop and better iats il do it.
Old 11-20-2013, 09:51 PM
SPRAYED 01's Avatar
I'm more concerned with the pressure drop as i now spray Meth
Old 11-21-2013, 04:56 AM
samdogmx's Avatar
Im going to be running the twin version. I will let you know how it does, next year.
Old 11-21-2013, 06:45 AM
9 Second Truck Club
stock48's Avatar
I run the vertical flow 3.5'' Tredstone and it's HOT but has got the job done so far.
Old 11-21-2013, 07:45 AM
Chevy406's Avatar
I run the TRTT9C Treadstone. In the 1/8th mile with 18 psi boost I was gaining 60° intake air temps. I have not measured pressure drop yet. Like you, I now use methanol injection to keep IAT within 7° of the starting line temperature.
Old 11-21-2013, 07:50 AM
SPRAYED 01's Avatar
Stocl48, how hot are wev talking about?
Old 11-21-2013, 07:55 AM
9 Second Truck Club
stock48's Avatar
200+ on a 100 deg day at 20 psi. Not sure that much else would do better tho considering the conditions??
Old 11-21-2013, 08:36 AM
skinnies's Avatar
I run the 1000hp treadstone version, 8.3 at 171 on 25lbs, less than 2psi pressure drop, iats are over 200 though. If you plan on keeping the car and a2a, get a shearer fabrications one.
Old 11-21-2013, 09:16 AM
SPRAYED 01's Avatar
Very hard to spend $1500 on a horizontal a/a plus the fab work and material to get it to fit. At the end of the day that's 2 grand, seems crazy to get the shearer.
Old 11-21-2013, 11:43 AM
Chevy406's Avatar
Check into buying a Bell core and having some custom end tanks made for it. Might be able to work with your existing plumbing.
Old 11-21-2013, 11:55 AM
bRAZENLS2gOAt's Avatar
I run the 1300hp center outlet treadstone. with meth & 22psi my IAT's are in the 60's at the end of a run.
I run one of the CRX racing 36in horizonal intercooler in the beginning, and i picked up 5psi when swapping to the treadstone.
Old 11-21-2013, 12:30 PM
You are spraying on the sensor guaranteed
Old 11-21-2013, 05:42 PM
SPRAYED 01's Avatar
Ya i think my actual iats are not very accurate with the meth on. I have the nozxles a foot away and its reading a 80 90 degree drop from no meth. I doubt that's correct but cool to see.
Old 11-21-2013, 05:57 PM
Forcefed86's Avatar
Just run another 140$ cx cooler just like the one you have in parallel.
I run the same cooler. 5lbs is pretty nutty... I'll have to look into other options as well. Thanks for logging that info!
May look at the procharger units too.They are similar.
Heres one for a decent price.
http://www.ebay.com/itm/PROCHARGER-RACE-3-CORE-3-INLET-BILLET-INTERCOOLER-/271306838107?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f2b25d05b&vxp=mtr
Old 11-21-2013, 06:14 PM
Sprayed post up your ic again. I thought u had a cheap tube and fin deal not the CX bar and plate?
Old 11-21-2013, 06:25 PM
SPRAYED 01's Avatar
http://www.streetmachineclub.com/fea...t--01-trans-am
At the bottom check picture 5. I could be wrong about it being a cx, i bought it like 5 years ago.
Im on my phone so the link is the best i can do to post pictures.
Old 11-22-2013, 05:54 AM
THADD's Avatar
Smart man here! I called Bell and had them build my intercooler. Go verticle. Forget anything horizontal. Here is mine.
Old 11-22-2013, 06:27 AM
Forcefed86's Avatar
Attachment 427426
Attachment 427427
Looks nice, what did that end up costing?
Quick Reply: Any one use the 1300hp thread stone IC?
