Need help deciding on a turbo.
OK guys, maybe I'm to indecisive I don't know. I've asked for quite a few opinions,and well you know hoe that goes everyone has their favorites.
My car (98 camaro) has a .30 over lq9. I don't plan to ever go larger than a 408, and that will be a long while., probe pistons, eagle rods,stock crank, compression is around 8.4:1, cam is a 228/232@50 598/612 on a 114+3 lsa. 317 heads though i look to get some with a thicker deck surface later on, ls6 intake ,fast 78 tb, snow performance water/meth, hp performance turbo kit,that is a t4. (currently a 67mm)
OK the turbo i personally want is a pt8847,but that's not in the budget and cant seem to come across a used one. So my question is, do I just suck it up and save for what i really want or is there a cheaper alternative that i could use? My hp goal is to see 930s at the wheels (though I'm sure once that's hit it will become 1000) Power put to the ground through a th400 and a 12bolt.
Now if anyone remembers this kit,the turbo is mounted where the battery was so size is a little bit of a factor. I can cut a little. Thanks for the recommendations.
They are making that with all the way up to a 92mm wheel aren't they? Which one would be better? 83,87,or 92
Here is where i get confused or maybe just over thinking. If you have a the s476r with a say 92 mm billet wheel and a s480r with the same. outside of the apparent compressor housing,whats going to be the difference? sorry to throw in another question.
1 Post
Call Jose at Forced Inductions and he will steer you straight. I also have a 370 and he is building me a badass Billet S480 ET-R HO right now. I have a T6 flange but I believe he can make it in a T4 as well...
