V-Banded Stainless "Truck Manifold Style" Manifolds X-Mas/End of Year SPECIAL!!!
X-Mas / End of Year Sale!
Truck Manifold Style, Stainless V-banded Manifolds
Normally: $450
Now through Dec. 31, 2013: $375 SHIPPED!
New product to help those DIY kit builders, or for those looking to enhance their current set-up with a nice set of v-banded manifolds without the hassle of having to modify cast factory manifolds!
http://www.shop.huronspeedproducts.c...s-truckman.htm
Designed after the ever popular "truck manifolds" for 98-02 LS1 f-body Turbo Kit applications. These come in a stepped header design to maximize flow, give great appearance, great strength out of Stanless Steel, and V-banded connections for ease of fabrication!
These are a great choice for those wanting to build their own turbo set-up or modify their current kit to utilize a V-banded manifold without the hassles of modifying a cast truck manifold and deal with welding the tricky cast.
Features:
Complete Stainless Steel, fully polished for a great look!
2.5" V-bands with step for perfect alignment
Stepped runners for best performance and flow
45mm-51mm-63mm Stepped Runners
1 Year Warranty against any issues!
Includes clamps and a set of flanges to build off of as well!
Standard pricing is set at $450 per set
X-Mas / End of year pricing set at $375 SHIPPED for the set through Dec. 31, 2013!
Order your set here: http://www.shop.huronspeedproducts.c...s-truckman.htm
With these facing forward, on the drivers side manifold for the steering shaft, the main runner for the log stays within 4" to the head side of the flange. The log runner tapers out a bit, so out by cyl 1 it is near 4", but back by cyl 5 it is about 3.5" from the head.
On the f-bodies we have a good 2 fingers of clearance to the steering shaft!
Normally: $450
Features:
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Yea, 43mm ID on the primaries
__________________
Yea shouldn't be an issue, they are very strong….. and also warrantied
__________________
We will have an ac retaining manifold in the future!
__________________
No idea on a date as we haven't even started the project yet, just an idea as of right now if the demand is there!
__________________
Not necessarily, these manifolds are MUCH easier to work with for a small or minor tweak that a cast factory manifold!
__________________
I need to get a set to test out! Would be great info to have but I currently do not have a 6 bolt set-up around to test. Soon as I do I will post up the info or if anyone has a 6 bolt set-up and wants to test it out, shoot me a PM!
__________________
Thanks!
I'll get weights of these and factory truck mani's here ASAP
__________________
