Rear mount positives and negatives.
Old 02-07-2014, 10:27 PM
LSFreak13's Avatar
Default Rear mount positives and negatives.
I'm not much into the whole rear mount community but I was curious as to the good and bad to having a rear mount?
Old 02-07-2014, 11:30 PM
HexenLord's Avatar
Putting it at the back means all of your piping/lines have to be routed to the front.
Being further away from the engine means the exhaust will be cooler and take longer to spool the turbo.
Old 02-07-2014, 11:34 PM
LSFreak13's Avatar
So it more or less used for vehicles who don't have a sufficient room under the hood?
Old 02-07-2014, 11:49 PM
HexenLord's Avatar
Sounds about right.
Old 02-08-2014, 12:16 AM
ZGLASS's Avatar
my build if it helps sway you any. made 837/840 running out of fuel around 900whp.
http://forums.corvetteforum.com/c5-f...unt-c5z06.html
http://forums.corvetteforum.com/c5-f...o-results.html
Old 02-08-2014, 12:21 AM
Cajun ELESS-ONE's Avatar
pro- cooler charge due to the extra length of pipe dissipating the heat.
con- routing the extra piping/oil lines, and turbo lag. also watch driving in the rain. the turbo intake can suck up water if you hit a big puddle
Old 02-08-2014, 12:33 AM
ZGLASS's Avatar
isnt any lag if you do it right. mine spools faster then just about any front mount car i have seen. boost by 2-2200 rpm, response is nuts. Drive it in the rain no issues. However we tucked the turbo high and tight.
Old 02-08-2014, 01:12 AM
HexenLord's Avatar
Physics says you cannot possibly spool as well as a front mount.
Sure, if a rear mount is done right, you won't have any issues with it. Going with a rear mount is a decision you have to make based on what you're working with.
If done right, it will work very well.
Old 02-08-2014, 11:21 AM
LSFreak13's Avatar
Wouldn't the best place to put a rear mount would be up above the rear axle?
Old 02-08-2014, 11:39 AM
HRHohio's Avatar
I love mine.
One more pro..... I get to keep AC and don't have to do much in the engine compartment. Engine area stays pretty much stock. Under hood temps may be cooler too.
Old 02-08-2014, 11:53 AM
HRHohio's Avatar
Also, as is any turbo setup, if it is designed and tuned right... no difference other than location.
https://ls1tech.com/forums/forced-in...lts-759hp.html
Old 02-08-2014, 02:21 PM
runsfromdacops's Avatar
my rear mount spools instantly and makes allmost 900 whp.
the biggest problem with a rear mount turbo to me is oil control.
in a rear mount setup turbo selection is much more important then in a front mount
Old 02-08-2014, 02:40 PM
LSFreak13's Avatar
Is the oil problem with the return? Because the regular turbo mounts are controlled by gravity and the turbo is higher than the oil pan and the rear mount isn't as high? And what makes the turbo selection different?
Old 02-08-2014, 03:14 PM
qqwqeqwrqwqtq's Avatar
I wouldn't mind seeing some screen shots/data logs of these instantly spooling rear mounts.
I've driven several and not one of them could compare to the response of a conventional turbo system. (part throttle most noticeably)
Old 02-08-2014, 04:51 PM
sbcgenII's Avatar
02 sensors can't read as fast in the rear of the car and now turbos are spooling faster back there!
Old 02-08-2014, 05:15 PM
tennerv8's Avatar
The closer the turbo is to the exhaust valve, the faster it will spool. Period.
Old 02-08-2014, 05:59 PM
ZGLASS's Avatar
hard to compare apples to apples obviosly.
ttx kit on a forged 346 auto c5z06
built ls2 ttx kit auto c5
Built c6z06 with a ttx kit.
ls1 firebird single front mount 7675 6speed.
my single rear mount 7175 stock bottom 5.3. c5z06.
seems like mine spools better then some combos that should spool faster then mine?
Old 02-08-2014, 09:13 PM
Brian Coles's Avatar
Not to
Is there any better option if you live in hot climate, want to keep A/C, and dont want to replace k member ??
Old 02-08-2014, 10:47 PM
WstSidHomE's Avatar
Originally Posted by Brian Coles
Not to
A turbo/twin setup like the APS kits would suit these conditions. Another company or two designs their twin kits like this and you can always do a custom setup. They mount the turbos at the rear of the engine, where normal shortie headers/stock manifolds would connect to the y pipes. They're still low mount so an oil return pump is still needed, but you would still get to keep A/C and stock kmembers.
This is only if you don't want to go rear mount.
Old 02-08-2014, 10:58 PM
LSFreak13's Avatar
Well at that point you might as well just do a rear mount
Quick Reply: Rear mount positives and negatives.
