4.8 turbo pt88
4.8 turbo pt88
What do you guys think about putting a precision pt88 on a 4.8l used strictly for drag racing. Will have custom cam ground and ported 862 heads. Running turbo 400 trans with trans brake. Also have single plane intake w edlebrock elbow and 102 tb, 96lb injectors. Looking to run 110 race fuel and a/w intercooler.
Car is 3400lbs race weight. Looking to achieve 8-900rwhp+.
Any suggestions. Thanks
PTE's PT88 Turbocharger features the following:
• 88mm inducer compressor wheel
• Compressor cover options:
- "H" compressor cover 4.0" inlet/3.00" outlet
• Turbine housing options:
- T4 Tangential .96 A/R with 4 3/8" V-Band discharge
• Hydrodynamic 360° thrust bearing system
Why not go with a smaller more efficient turbo? You could make your goals on a much smaller billet wheel and have significantly better spool and be able to build more boost on the line. 800-900 could be done with a billet 72mm.
Otherwise you'll end up being one of those people who play into the myth that turbos don't make torque because of the lag because you picked a 1300+ HP turbo to make 800 hp.
I'm not saying it won't get the job done, because it will. It just isnt ideal.
To hijack just a little... What do you guys think of a Precision 76mm on a 402 in my Silverado? (Specs in sig) Goal of 7-800whp. Basically only street driven.
