First startup tune
Old 02-24-2014, 10:36 AM
topgun542's Avatar
Default First startup tune
hi guys, i wanted to ask how you go about tuning on a fresh motor? Im getting ready to startup my first built motor. I did it myself and wanted to know how you go about tuning and also breaking in a new motor. I might be over thinking it but should i get a base tune then break it in or just tune and break in?
Old 02-24-2014, 11:00 AM
THADD's Avatar
The only things to really break in is the rings. This happens fairly quick. I would get a base tune put in the break it in. It's also better to do it under a little load like on a dyno and getting the rpms up some
Old 02-24-2014, 11:17 AM
topgun542's Avatar
I knew the rings need some load... ill be doing the tuning myself so basically just base tune it and go find some hills?
Old 02-24-2014, 01:32 PM
Forcefed86's Avatar
LS1Tech 10 Year
I like this guys take on it...
http://www.mototuneusa.com/break_in_secrets.htm
From what I've read roughly 80% of ring break-in occurs in the first hour. Having known spot on tune is best IMO. Fire it up and go beat the snot out of it alternating between short bursts of hard acceleration and deceleration. Also says wind vehicle weight etc take car of most of the load, no hills necessary.
I took the WG off to break in motors. Not that boost is bad, but I couldn't make less than 9lbs or so.
Old 02-24-2014, 02:06 PM
topgun542's Avatar
sooo basically, start it, make sure it isnt loosing parts... and make sure the tunes sort of making it run, then go drive it?
Old 02-24-2014, 02:13 PM
Forcefed86's Avatar
LS1Tech 10 Year
No...
Make sure it isn't losing parts...then beat the snot out of it.
Old 02-24-2014, 03:27 PM
RonSSNova's Avatar
One thing you want to make sure though is that it's not pig rich.
So if everything seems happy, yes, just go drive it.
Modern rings seal nearly instantly if the bore finish is correct.
Old 02-24-2014, 06:01 PM
topgun542's Avatar
I use hptuners, what kind of scaling could i use for VE to make it run? or should i just get one of of the repository that sort of matches?
Old 02-24-2014, 06:02 PM
Moderator
denmah's Avatar
what is your setup, i have a ton of base tunes for 60-80lb injector LS cars
Old 02-24-2014, 06:38 PM
topgun542's Avatar
haha My names matt, i was just talking to you on fb, i saw your tunes on your wiki and thats why i was asking about those ifr tables cause i started making my tune for my car recently.
Quick Reply: First startup tune
