Anyone use the ls1 style 3 bar map sensor from efisource.com?
I was just wondering if anyone had experience with the efisource's ls1 style 3 bar map sensor, and if it's better than Dsteck's 2.5 bar map sensor?
in demah's build pics, i usually see the "GM 3 bar" with the 3 tube style pigtail that needs to be spliced in. I wonder if that's what he's referring to. this one I'm inquiring about, is a direct plug and play, ls1 style.
yes this plugs in, directly into the stock harness
it has the stock plug
it looks like an ls1 sensor with the hooks on one side
it plugs into the stock wiring
no cutting or soldering or anything
it uses the same value's as a regular 3 bar sensor
305 : 10.33 is what i have been using for every sensor i have setup
http://www.efisource.com/shop/ls1-st...ar-map-sensor/
LS1 style 3 bar MAP sensor
$35
LS motor direct fit 3 bar map sensor.
EFI Source is now offering a “plug and play” 3 bar map sensor for the LS series motors. It directly replaces your stock map sensor, utilizing the stock port on your intake manifold as well as the stock connector.
$35
I know this is a older thread. I just bought the EFI 3 bar map and it does not fit like the factory GM 1 bar that I have in my truck intake. Why is there only one clip provision? I emailed them for a answer but I figured Denmah will know. I put a wire tie around the two clips to hold it but that is just not right. Thanks
just plug the map hole, and bust off the barb on the passenger side of it and connect a vac line to the map, much easier, im not a fan of the wobbly stock map sensor plugs at all with the skinny arms holding them on
I got one of these sensors last spring and it never did work right. Used denmahs set points along with someone elses and it always just read like 110 kpa at idle and like 70kpa with key on engine off I think it was.
Maybe just a bad sensor who knows. I never did return it even tho they offered a full refund. Just went and got a cobalt ss 2 bar instead and set that up. Worked just fine..
