Single Turbo kits $799.00 Use coupon code for discounts!
Old 04-09-2014, 02:08 PM
Chris@CBR's Avatar
Default Single Turbo kits $799.00 Use coupon code for discounts!
Some of you will remember this kit.
We will be making a run of these kits very soon.
They should be ready in 4-6 weeks.
Price $799.00 plus shipping
Requires truck manifolds.
Here are the benefits of this kit.
Retains the stock K-Member, That's about $650.00 you don't have to spend!
Retains the stock fans, That's about $300.00 you don't have to spend!
Retains the stock radiator.
NO cutting of the radiator support!!
Let me be clear about the oil return from the turbo, I recommend using a oil return pump.
However, we have customers that tell us that they ran the return hose
up and over the K-member and in the oil pan and the oil returns just fine.
Old 04-09-2014, 02:16 PM
87silverbullet's Avatar
I need one that keeps the A/C Chris. You know damn well its too hot out down here in the summer.
Old 04-09-2014, 02:23 PM
Chris@CBR's Avatar
Oh I know, Some guys can live with out it, Not this fat boy!!!
Old 04-09-2014, 04:06 PM
sbcgenII's Avatar
Can i buy the motor mount separate?
Old 04-09-2014, 07:22 PM
Chris@CBR's Avatar
We had other guys ask for the mount in the past.
I'll make a few extra if you what one.
Old 04-09-2014, 07:44 PM
Captain Double Post
BOBS99SS's Avatar
I'll try one out. When will they be ready? A few weeks?looks nice
Old 04-09-2014, 08:58 PM
x275radial's Avatar
looks nicer than most the crap I see on here for high dollar. good luck very nice and simple product. also like how you made it in as little cuts as possible.
Old 04-09-2014, 09:05 PM
Lil'John's Avatar
Do you happen to have other pictures of this it in use? Maybe a build thread showing it and extra parts needed?
Very tempting as my current exhaust sucks and I'm looking for a good excuse to get rid of it/upgrade
Old 04-09-2014, 09:10 PM
Randolph Ziskey's Avatar
This requires removal of ac?
Old 04-09-2014, 09:11 PM
Chris@CBR's Avatar
Lil'John: We sold 10 of these kits a few years back. One guy reported just over 600 rwhp @ 11 psi.
Maybe some of those guys will chime in with there results.
Old 04-09-2014, 09:12 PM
Chris@CBR's Avatar
Yes it does.
Old 04-09-2014, 09:17 PM
awww..ac is a necessity with this dam heat
Old 04-09-2014, 09:22 PM
aknovaman's Avatar
Move your ac compressor up high on passenger head.
Old 04-10-2014, 09:10 AM
95bowtie's Avatar
Pretty sure I met someone at the track with this kit. I want to say he had a oil return pump like recommended. Had to actually look for the turbo it's almost hidden down there.
Old 04-10-2014, 09:50 AM
Blackpanther99's Avatar
With you on that one living in Texas, that's a good price regardless though.
Old 04-10-2014, 10:08 AM
It is an amazing price!!!!
Old 04-10-2014, 12:39 PM
Photochop's Avatar
Could you please post some more pics of the kit installed? I did a search and some previous pics showed having to notch the factory k-member.
Could you post some pics of a completed kit with a cold side on to show ideas for how one would run?
Would a Turbonetics TC78 w/ a 1.15AR exhaust housing fit?
Would a generic ebay type 60mm wastegate fit?
Old 04-10-2014, 12:56 PM
abritton77's Avatar
What all is included?
Old 04-10-2014, 01:40 PM
Chris@CBR's Avatar
What you see in this pic is included.
It comes setup with 2 bolt flange that fits Tial 38 mm style gates.
We use a Tail 38mm gate in the fixture when welding the WG flange.
I if you want to use a difference type or style of WG you will have to make those changes yourself.
The gate placement optimal and a 38mm gate will do the job on any turbo that will fit the kit.
We used a Turbonetics TC turbo in the building of this kit. That turbo can purchased with a 78mm comp wheel and 75mm turbine wheel.
The stock K-member will some adjustment on the passenger side. I heated the one in the pic's with a torch used a hammer to make the adjustment.
If your hammer is big enough you won't need a torch, Or you could just notch it with a saw. It doesn't take a whole lot to make it clear.
Old 04-12-2014, 10:33 AM
98noscamaross's Avatar
Ive got this kit on mine. With a cam only 5.3, stock ls1 intake, through a th400 im at 736rwhp on a notoriously low reading dyno. Im running a turbonetics 7875 on mine.
Quick Reply: Single Turbo kits $799.00 Use coupon code for discounts!
