E85, do I need to change anything in my set up?
Old 06-27-2014, 08:01 AM
BALBI's Avatar
Default E85, do I need to change anything in my set up?
Please educate me. I have done some reading and decided I want to run E85 daily. I have plenty of pumps near me, seems like a win win all around.
The car is a 99 Camaro Z28, I have a D1-SC Procharger with a forged 383 running 60lbs injectors and an upgraded fuel pump. Injectors are at 85% capacity and I am running only 8psi.
My tuner tells me I need approximately 30% more fuel injector and pump capacity to equal the same power as I do with pump gas. (560whp)
Do I really need to change anything? I was under the impression I could just tune and move on.
Thoughts?
Old 06-27-2014, 08:20 AM
Restricted User
JoeNova's Avatar
So your injectors are 85%, and you know you need 30% more fuel, but don't think you need to change them?
Also what fuel pump are you using.
Old 06-27-2014, 08:48 AM
willizm's Avatar
x2 on fuel pump. If you aren't going to push too high you could probably go 95lb injectors and dual 255 pumps. I ran that on e85 without a problem. Made 750whp at 15psi
Old 06-27-2014, 09:00 AM
SM105K's Avatar
You need more fuel pump, and more injector.
Old 06-27-2014, 09:22 AM
BALBI's Avatar
My math teachers asked the same thing for years
Using Racetronix 255
Old 06-27-2014, 11:50 AM
Restricted User
JoeNova's Avatar
You're going to need more injector and fuel pump. Your pump is already topping out on gas now. Your injectors, judging by the duty cycle, aren't going to cut it.
AEM sells a nice 320 LPH made just for E85. They're $120 from scoggin dickey, and a pair of them is good for however much power you'll ever decide to make on that blower. Racetronix doesn't recommend using their pumps with E85 because of rapidly reducing shelf life when exposed to E85.
I would get at least 80 lb injectors. No point in overspending on them, though. 80 lb deka injectors are 320-340 on ebay and work great.
Old 06-27-2014, 11:53 AM
greenvortec97's Avatar
So would -8 and -6 return be good enough for E85? assuming you have the proper injectors and pumps? not meaning to thread jack
Old 06-27-2014, 11:57 AM
Restricted User
JoeNova's Avatar
Yes, -8 feed is more than enough for most feeds and will support well over 1000whp on E85
Old 06-27-2014, 01:15 PM
Forcefed86's Avatar
Thoughts?
What is your base fuel pressure at now?
For 560 WHP there's no need to change the fuel lines. Get 2 intank walbro 450's pumps. ($134 shipped each) I think that and a retune is all you'll need. At only 8lbs of boost, you should be able to make up the difference with additional fuel pressure and get by with 60lb injectors.
Quick Reply: E85, do I need to change anything in my set up?
