Aluminum exhaust- Street car
Old 06-30-2014, 06:27 PM
68II's Avatar
Default Aluminum exhaust- Street car
I'm really considering making my 4" full exhaust out of aluminum after the down pipe. Any one running it on a street car? Cracking a problem? 16 gauge thick enough? Thanks for any info.
Old 06-30-2014, 06:36 PM
Truck Sponsor
TrickPerformanceProducts's Avatar
We have a twin turbo lightning running around Fort Worth area for over a year.
No problems.
Dual 3" exhaust from down pipes to the front rear tire exit.
Freakishly light mufflers sounded nice as well.
Old 06-30-2014, 06:45 PM
68II's Avatar
No problems.
That's good to hear, do you remember what gauge tubing you used?
Old 06-30-2014, 07:01 PM
CAMSTER's Avatar
Aluminum won't crack just use good aluminum as the lower quality likes to shift and use more supports in hotter front area , I make my own mufflers using SS mesh true center. Save me over 40 lbs.
Old 06-30-2014, 09:57 PM
Driftin_240sx's Avatar
I have been running a dual 3" all aluminum exhaust on my Tt c6 for 2 years. No problems.
Old 07-01-2014, 12:42 AM
a-low's Avatar
Exclamation
Got any pics?
Old 07-01-2014, 12:49 AM
8 Second Truck Club
Blown06's Avatar
I'd probably run 11 ga until after the first bend. Then 16 should be fine.
Old 07-01-2014, 04:56 AM
68II's Avatar
The down pipe is already done in steel, the weight of it alone is what made me want to go aluminum the rest of the way.
Old 07-01-2014, 07:43 AM
Sarg's Avatar
I hear ya there. My 4" stainless downpipe is pretty heavy and it is just fender exit.
Old 07-01-2014, 08:07 AM
Truck Sponsor
No sure don't. I could hold both sides up with mufflers in place to tighten up the last hanger.
In guessing .065 or less.
Old 07-12-2014, 04:01 PM
CAMSTER's Avatar
Originally Posted by a-low
Got any pics?
Pix...
https://ls1tech.com/forums/generatio...ic-pg3-10.html
Old 07-12-2014, 05:11 PM
Chris@CBR's Avatar
CANSTER, that it a clean job!
14ga is a good balance between weight and strength.
Here is the way I hung Dan's system in the center to prevent drooping. Welding a tab or bracket to the tubing will eventually tare out. I split a piece of stainless 3" ID tubing to saddle the aluminum and used T bolt clamps to clamp it to the tubing. I welded my brackets to the saddles.
Hope this helps.
Old 07-12-2014, 06:24 PM
Boo"SS"t's Avatar
Chris, you should sell those aluminum dual exhaust as a kit with different options for mufflers on your website. You guys have built some pretty awesome stuff, you just need to market it more.
Old 07-13-2014, 12:07 PM
CAMSTER's Avatar
We expanded fit slip over then welded, else all the hangars we made out of aluminum, i welded on a 1 1/4 inch long halve pipe reinforcement then welded the hangars on it in this way there's no tear from vibration, note front hangars above the tubing and not visible, a 1/2 aluminum rod fits true a rubber muffler hangar for slip into place no bolts or screws installation, else is a 3 piece for ease of handling, at the track we remove the rear two pieces.
I used all ball and socket connection.
By the way we use four mufflers to keep noise low on three inch cause if not will be loud.
Incredibly the four muffler system is not much louder at WOT than it is at idle.
Old 07-14-2014, 10:42 AM
ls1curt's Avatar
I did 11 gauge for the first two bends and 16 gauge for the rest. Seems good so far.
Old 07-14-2014, 10:46 AM
Blackpanther99's Avatar
Hope this helps.
Looks well done!
Old 07-14-2014, 10:47 AM
Chris@CBR's Avatar
Thanks!
Old 07-21-2014, 04:40 PM
V-seriesTech's Avatar
Run .065 wall(16ga) for my AXLE back on my vette...made mufflers, etc..so far, so good. When I have some extra time and cash... we'll get rid of the steel mid pipes,..and also go aluminum.
Old 07-21-2014, 10:19 PM
norotor7's Avatar
Nice work on those mufflers.
I have 16 gauge stainless form the turbos down to the frame. About 3 feet. I have 16 gauge aluminum for the rest of the exhaust.
Old 07-22-2014, 12:57 PM
^^^ Thank you sir.
Quick Reply: Aluminum exhaust- Street car
