longtubes and a front mount turbo
im just starting my turbo build on my already ls swaped s10, im gonna put my s475 right behind the passenger headlight, but im having issues with fitting upside down manifolds due to my steering shaft, so i have been considering keeping my longtubes that wrap around the steering mounted normal and turning the piping from the collector underneath the truck back up to the turbo.
What will be some down sides to running my exhaust in this orientation?
im looking to make around 850 to the ground on this set up
i hear you there, what i am gonna try to do is run truck manifolds in traditional orientation and run my cross behind the oil pan and back up to the turbo and flip the manifold on the passenger side
my frame notched heavily for the longtubes i have been running with my current nitrous set up so with the passenger manifold flipped i will have a spot between the block and the frame to run my crossover pipe back up to the turbo, then the DP can run down and out at the front of the passenger door
Restricted User
There are a few manifolds out there that allow you to run the stock truck manifold on the drivers side. You then route the exhaust around and into the back of the passenger side turbo manifold that is basically a forward facing manifold on with a rear inlet. I know KBracing makes one. There is at least one other company out there that makes these.
