fuel injectors
fuel injectors
I have a 03 6.0 with a 76mm turbo. I only plan on running 11lbs of boost. Do I need to make a injector change from stock?
Thanks in advance.
Thanks in advance.
I went with fic1000s and was only planning on staying around 10psi. Glad Martin talked me into those injectors cause I pushed it to 23psi without having to upgrade them. I had 2 walbro 340lph in tank. Was on a ls1 with s475. Those injectors like 600$.
80lb siemens deka's are the best economical injector upgrade in my opinion
only around 325 dollars shipped, and will do 800-1000hp depending on transmission loss and fuel you're running
hard to beat the flexibility
