No water pushed, 9.84@144
Although 3 runs clean isn't a sure thing, it's a great start. Not a drop in the overflow.
I did several things.
Hand sanded the heads to completely remove the machining marks from my guys surface job. (We both messed up there)
Lightly did the same to the deck,
Switched to FelPro MLS blue perma torque gaskets that fit the bore on the L33.
Added a 4 corner coolant crossover from an LS1. Thanks Mikey!
.017 RT
1.65 60ft
9.84@144.04
Boost is right at 203 kpa in high gear. Full throttle half way through 2nd.
The track was good tonight. Ran out of time to try a foot to the floor pass.
The tuning changes have boost happening .5 sec quicker.
I also had to clean the injectors. Black goo from the E85.
For now I'm adding Lucas Ethanol treatment. I'll see how it does.
Ron
.017 RT
1.65 60ft
9.84@144.04
Ron
Reliability is a better result than getting times !
Are those the Felpro gaskets with the laser welded raised section at the fire ring ? There was some marketing hype at PRI a few years back about some new MLS gasket they had, but they never really seemed to become available.
$38 ea.
The black goo is probably old buildup from the previous fuel you ran. E85 will actually break down sludge inside an older fuel system and cause that. Most have to replace fuel filters frequently when first switching to E85 due to this.
Congrats on the passes!
Awesome Ron! Did you get any video this time around? You SAID you were going to get video next time!!!
What were the 1/8th mile ET and mph just curious? Good news on the timing also. Glad that is working out for you. Can't wait to try it out myself. You are pretty much running 30* in regions up to about 5psi?
Thanks guys.
The fuel system is pretty much all new except for the fuel cell. I do plan to remove the foam. It's old.
1/8 mile was 6.43@115
60 was actually a 1.68.
We did get a video. At night with a cell phone. Besides being out of focus, dark, and can't read the board, it was a good one!
Congrats Ron! With a good 60' you have already matched the performance of the 496/spray and you haven't even cranked the boost up yet..
22 psi and let'r eat.. 8.99999? Maybe so...
