Best way to setup initial startup without cold side?
I'd like to do an initial startup to check for leaks and electrical function before I fabricate my cold side and some other odds and ends. Is there a "best" way to do this?
Should I just hook up vacuum to the top of my wastegate and fire it up or what?
You do not need wastegates control plumbing plumbed up in order to start the engine.
All you'd want is to make sure they're bolted to the exhaust so they dont leak.
