5.3 L33 huron speed Turbo 880hp 17 psi
Old 08-27-2014, 11:43 AM
josh4ku's Avatar
Default 5.3 L33 huron speed Turbo 880hp 17 psi
Well I figured I would start a build thread, lots of parts have been ordered. I think i have everything planned out pretty well. This is a 2001 Pontiac trans am with an rpm transmission TR6060 Magnum level 7 & MWC fabricated 9".
Goals = Mainly wanting a fun street car that will turn heads everywhere I go. Looking to put down 800 rwhp. Boost will not be turned up that high very often.
-Engine-
Thompson motorsports forged shortblock rated for 1,200 HP
TMS 5.3 shortblock all forged
TMS forged crankshaft
TMS 4340 forged h-beam rods with arp rod bolts
forged diamond -3cc pistons
arp main stud kit
Tick spec cam 217/225 114+3 .637/.620
Hardened push rods
Johnson 2116LSR reduced travel lifters
PRC dual valve springs with titanium retainers
Cloyes timing chain
Trick flow timing chain dampener
TSP PRC as cast 225CC heads (9.6:1 CR ratio)
ARP head studs
Melling high pressure oil pump
Arp cam bolts
LS9 Head Gaskets
ls6 intake
Potz performance p&p throttle body
Ls1 ati stock diameter all steel dampener w/ arp bolt
Truck coils
Br7ef plugs
-Fuel-
Lonnies double pumper fuel system 255 & 340 pumps.
Injector dynamics 1300cc stainless injectors (high impedance)
Aem digital a/f gauge
Aem fuel pressure gauge
-Power Adder-
Huron speed v2 a/c retaining single turbo kit
Precision billet 7675 with .96 a/r
BMR turbo K member
Turbo smart hyper gate 45
Tial Q bov
Turbo wrap titanium fiberglass
Eboost 2 (boost controller)
Stainless works 3.5" catback with qtp electric cutout.
-Transmission-
Built tr6060 6 speed
Tick master cylinder
Monster lt1-sc twin disk clutch
High performance driveshaft
-Suspension-
MWC fabricated 9" rear end
3.70 gears
S trac posi
Suspension:
Subframe connectors
BMR LCA's
Viking coilovers
BMR panhard bar
MWC torque arm body mounted
Extra stuff non performance stuff:
Sound deadner under carpet and door panels.
sound system
Brand new recovered seats.
Car made 879 rwhp at 17psi boost.
Old 08-27-2014, 11:59 AM
2muchboostNY's Avatar
Sounds like a fun project.....sub'd
Old 08-28-2014, 11:12 AM
HolyShiznit's Avatar
No need to build it if it's already been opened up and checked. Also since it's a 2005 it has the Gen IV rods. Make sure it avoids detonation and let it eat. It will be fine.
Old 08-28-2014, 11:25 AM
josh4ku's Avatar
That was my plan to begin with, I better stick to it! Thanks
Old 08-28-2014, 05:34 PM
99T/AMAN's Avatar
In for the build! Looks good
Old 08-28-2014, 05:53 PM
josh4ku's Avatar
Thanks man
sweet99ss's Avatar
Looks like you have a good plan! Mine was going good tell I got to the oil drain.
Old 08-28-2014, 06:27 PM
josh4ku's Avatar
What happend there?
Old 08-28-2014, 06:40 PM
1bdbrd's Avatar
Looks like another fast car being built in KC. I am anxious to see what kind of power your setup makes.
Old 08-28-2014, 06:54 PM
josh4ku's Avatar
I am to , gonna strap her to the dyno this spring
Old 08-28-2014, 07:40 PM
1bdbrd's Avatar
I have basically the exact same setup ready to go into my car except I have the 1.15 a/r on my 7575. I am really really curious how far this turbo will go on a 5.3. I am hoping 850+whp but I guess we will see.
Old 08-28-2014, 08:26 PM
b16gsr's Avatar
looks great should prove for a good build, there is a better tuner option to be honest.
Old 08-28-2014, 09:07 PM
josh4ku's Avatar
Who? Not to many options where I live
Old 08-28-2014, 10:02 PM
1bdbrd's Avatar
He's probably going to suggest Ryan (MaxMitchell on here). He lives near us and does a really good job with tuning.
Old 08-28-2014, 10:08 PM
josh4ku's Avatar
Street tune?
Old 08-28-2014, 10:14 PM
1bdbrd's Avatar
I think that's how he does most of his tunes but I am not 100% for sure on it.
I decided to do my own tuning. I figure on e85 and low boost I should have a decent enough margin of error to learn what to do and not to do. Plus I had a lot of fun tuning my NA truck.
Old 08-29-2014, 06:26 AM
b16gsr's Avatar
He is correct.
Street tune?
Yes and dyno.
He works out LSXKilr in Lawrence. He actually spends time dynoing the car, the polishes it up on the street. Skinnies and MaxxMitchell actually created a dual fuel setup with a double injected intake manifold setup to have both e85 and pump gas running off the stock ecm.
Old 08-29-2014, 08:10 AM
josh4ku's Avatar
Really that sounds interesting
Old 08-29-2014, 02:28 PM
1bdbrd's Avatar
He is correct.
Yes and dyno.
I didn't know the Ryan had teamed up with Mo (I think is his name?) at his shop. I have known Ryan and Justin since way back when Skinnies still had a nitrous Lt1 and Ryans car was a carbed 383. Both really good guys who will help however they can.
Old 08-30-2014, 02:37 PM
josh4ku's Avatar
What do you guys recommend speed density 2.5 bar tune vs maf?
Quick Reply: 5.3 L33 huron speed Turbo 880hp 17 psi
