Meth Solenoid Location
Hey,
Ive had a meth injection kit in the past which was located in the engine bay so I was getting instant meth when I needed it. I have since changed vehicles and mounted the system in the trunk which is requiring me to use a solenoid so I dont leak meth. Anyway, the directions say to put it between the tank and pump...
My question is; Why wouldnt I put the solenoid close to the injection nozzles so I still have meth in the line ready and waiting for the boost to come on? If I had the solenoid back by the tank and pump I would have a delay.
Thanks,
Zak
Thanks,
Zak
Are your nozzles in the intake manifold, or just pipework prior to the throttle ?
That will largely dictate the cracking pressure of any check valve used.
I assume the fact you used a solenoid before, the nozzles are in the intake itself ?
