Best 3 bar MAP for 411 pcm
What is the best 3 bar map to run with an 01-02 411 pcm. Will be doing a pcm swap and want to do this at the same time. A part number and/or link would be great
Sooo OS stands for what operating system? I also have a 411 PCM out of something like a 01 V6 Astro. ... I was told by PSI harness that any 411 would work fine with my HP tuners pro and a 3 bar?
Various vehicles used various Operating Systems.
Some if these simply won't convert to 3 bar. Some will convert to 3 bar but with a reduced resolution VE table.
Others convert with a nice high resolution VE table.
I can say that the 99-00 Fbody OS works well. Even if it's in the 0896 PCM. I'm using one in my nova.
If you have a 0411 PCM, no guarantee the OS in it converts nicely. But you can rewrite the PCM with a 99-00 Fbody OS then convert to 3 bar. But that would cost 6 credits. Prob best to somehow get a PCM with a convertable file. There must be a list somewhere.
Well The tunethat I have loaded now is for an 01 Camaro Firebird so we will see ...what about ordering this MAP sensor?these guys know their stuff don't they? LOL
http://www.tickperformance.com/gm-3-bar-map-sensor-for-lsa-and-ls9-engines/
http://www.tickperformance.com/gm-3-...d-ls9-engines/
