Ring gap?
Old 10-13-2014, 02:55 PM
ul-ss's Avatar
Default Ring gap?
I have a low mileage lm7, im pretty sure he said it was around 8k miles on it. I was reading it is important to open up the ring gap on lower mileage motors. But I was wondering how big of a gap? Thanks for any help
Old 10-13-2014, 03:30 PM
transaminator99's Avatar
if your staying n/a leave it alone ..if your going boost .028 top ring
Old 10-13-2014, 03:41 PM
ul-ss's Avatar
I'm going to be going boosted shooting for around 600whp
Old 10-14-2014, 12:56 PM
ul-ss's Avatar
so is .028 good for the top and stock botttom?
Old 10-14-2014, 01:43 PM
2muchboostNY's Avatar
From what I understood you do not want to gap both rings to the same size as it creates flutter. Dont quote me on this but I believe the top ring should be gapped up to 0.025 and the bottom ring can be gapped a bit more. I wouldnt hold me to that but there are threads on here with real world data.
Old 10-14-2014, 01:53 PM
Forcefed86's Avatar
.006 x bore for top
.0064 X bore for bottom
Pretty standard and even overly "safe" for forced induction. So .022 and .024 is fine for a 5.3 IMO.
Old 10-14-2014, 02:39 PM
Moderator
denmah's Avatar
its hard to go wrong with 28 top and 24 bottom
Old 10-14-2014, 03:03 PM
Forcefed86's Avatar
I'm lost, why would you gap the top larger than the bottom?
Straight from Weisco...
http://www.aa1car.com/library/ringendgap_wiseco.pdf
The gap on the second ring should always be larger than the top ring end gap, this will
help to reduce top ring flutter or lifting.
Other stuff I read says you don't need to worry about ring flutter unless your reving the engine over 8000 RPM... so who knows.
Old 10-15-2014, 12:34 PM
toytech93's Avatar
I read somewhere forged pistons can handle slightly tighter gaps .006 x bore. compared to hypereutectic pistons .0065 x bore. Anyone ever hear of this before ?
Old 10-15-2014, 02:22 PM
ul-ss's Avatar
.006 x bore for top
so a .024 gap for the top and stock bottom would be a safe route?
Old 10-15-2014, 02:59 PM
Forcefed86's Avatar
Not really. You want the bottom gapped wider than the top. (from what i read anyway) If you went .024 on top go .026 bottom. Though as many have proved doing otherwise isn't going to cause major issues.
Old 10-15-2014, 03:54 PM
Moderator
denmah's Avatar
i have always read opposite, this is why i dont touch the rings at all lol
Old 10-15-2014, 10:44 PM
soundengineer's Avatar
I never re-gap rings....
I always put on new ones, and you set it by the manufacturer recommendations... every brand of rings has their own specs that they want to see for optimum performance and life.
its is always based on Bore size and type of power(NA/N20/FI)
Old 10-16-2014, 10:17 AM
RonSSNova's Avatar
The rings in your engine are now perfectly worn to the bore.
First thing you need to do is disassemble it and measure the gaps.
Mine had 126k. The tops were .019" and the second was .028".
I opened the top to .024" to .025". I left the second alone.
The bottom ring is the oil ring. Leave them alone.
BTW, from everything I've read, the stock rings are excellent. Hard to beat them going aftermarket. They are also quite expensive to buy from GM. Another reason to re-use them.
Lastly, don't mix them up cyl to cyl.
Quick Reply: Ring gap?
